polishing LSI9/LsiC
quicksilvergts
in Speakers
Howdy all!
I am curious what you Lsi owners use to polish the black on the Lsi lineup or Lsi9/Lsic?
I have some Meguiar's Ultimate Polish, I tried a VERY small spot on the bottom. wasn't to happy with the finish. mine are not that bad just want to clean them up. I usually just wipe them down with a Microfiber towel
One more question. on the Ebony Lsi does anybody use something for the panels too?
Any recommendations are much appreciated!
THANKS!
Cheers!
THANKS!
Cheers!
Polk Lsi9
Polk LsiC
Polk Fxi3
Pioneer SC-1222
Parasound 1200 II w/ Kimber Kable HERO + 4TC
SVS PB12-NSD (Bash)
PS4
Sharp Aquos 55"
"If your BOLD enough to try it,
your BOLD enough to make it happen"
Polk LsiC
Polk Fxi3
Pioneer SC-1222
SVS PB12-NSD (Bash)
PS4
Sharp Aquos 55"
Clean wood panels with furniture polish and a soft cloth. Do not use furniture polish on black gloss veneer.
Clean black gloss veneer with a damp cloth.Some final words,
"If you keep banging your head against the wall,
you're going to have headaches."
Warren -
Roger that on the furniture polish.
How about getting the scratches/swirls out on the black gloss?
Cheers!!Polk Lsi9
Polk LsiC
Polk Fxi3
Pioneer SC-1222
SVS PB12-NSD (Bash)
PS4
Sharp Aquos 55"
your BOLD enough to make it happen" -
Yea I don't think furniture polish is a good idea many are silicone based and just attract dirt and dust. On my real wood SDA's I use Johnston's paste wax. Rub it on with soft cloth let dry a little and rub off with clean towels. One trick I remember from all the woods classes taken in high school except we used 000 steel wool there. I did use steel wool to apply on mine but you be the judge whether it would work on your panels. With the gloss black I'd probably stay with soft cloth.
For the Lacquer ... Gibson guitar polish... get it on amazon or at guitar centerMy New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
Mikey, anything local maybe? We have one music store in town I'll check that one out tomorrow.
My main concern is the scratches/swirl marks and such.
Thanks all!
Cheers!
Polk Lsi9
Polk LsiC
Polk Fxi3
Pioneer SC-1222
SVS PB12-NSD (Bash)
PS4
Sharp Aquos 55"
You don't need polish, waste of money. Wipe with soft damp cloth, done.
That gloss black isn't lacquer, IIRC. I believe it's plastic.Political Correctness'.........defined
President of Club Polk -
So I just keep truckin it with scratches swirl marks on it? Lol. I do use a damp microfiber cloth along with a dry one when routinely cleaning.
Cheers !Polk Lsi9
Polk LsiC
Polk Fxi3
Pioneer SC-1222
SVS PB12-NSD (Bash)
PS4
Sharp Aquos 55"
Polk Lsi9
Polk LsiC
Polk Fxi3
Pioneer SC-1222
SVS PB12-NSD (Bash)
PS4
Sharp Aquos 55"
There are products that are supposed to remove light scratches from plastics. Like I said though, I think it is plastic, so best check with Polk first.I do use a damp microfiber cloth along with a dry one when routinely cleaning.
That should be fine.
I dont think polish will remove surface scratches unless you are removing a layer to even out the scratches or adding a layer to the scratches even out the surface.Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
I used to have a black Honda Magna that drove me nuts with "spider webbing" like that. Now, try this on a hidden surface first--but I found the only thing that worked was clear coat sealant. I'd lay the sealant first, then wax and I had a deep shine. You could also try polishes for motorcycle/atv/windscreen plastics.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Thanks you for the info and suggestions eveybody!
I tried calling Polk but unfortunately it's to late when I get home. I will try next week and also give those recommendations a go.
Thanks again!!!
Cheers!!
RichardPolk Lsi9
Polk LsiC
Polk Fxi3
Pioneer SC-1222
SVS PB12-NSD (Bash)
PS4
Sharp Aquos 55"
I've used "Mothers" Plastic Polish in the past. Works well on colored plastics.
http://www.mothers.com/02_products/06208.html#&slider1=19Home Theater/2 Channel:
dhsspeakerservice.com/ -
Great! I am going to Walmart later for groceries. I will pick some up or stop at auto zone thanks!
Cheers!Polk Lsi9
Polk LsiC
Polk Fxi3
Pioneer SC-1222
SVS PB12-NSD (Bash)
PS4
Sharp Aquos 55"
