hum ... hum ... and more hum
bamamusicfan
I've incorporated into my home theater system a new ATI 300 watt amp. It's a beast! Everything sounds great when listening to music, but when I incorporated my Dish Network receiver into the mix, I get a very audible hum. If I disconnect the sat cable from the sat receiver it will go away.
My amp owner's guide says to install a 75ohm ground loop isolator. Will installing the ISO-MAX CATV-compatible "Hum-Stopping" Ground Loop Isolator from the POLK website, eliminate this? I've tried some cheaper items that did not work.
Thanks for any help!
Bryan Miller
Athens, Alabama
Bryan Miller
Athens, Alabama
Post edited by bamamusicfan on
Hello Bryan,
I believe you sent this question to our regular customer service email system, correct? If so, did my reply help?
Regards, Ken -
Yes. Thanks!
Bryan Miller
Huntsville, Alabama -
Mind sharing a little of the info on the fix and the results???More later,
Tour...
Vox Copuli
