hum ... hum ... and more hum
bamamusicfan
bamamusicfan Posts: 25
edited October 2004 in Troubleshooting
I've incorporated into my home theater system a new ATI 300 watt amp. It's a beast! Everything sounds great when listening to music, but when I incorporated my Dish Network receiver into the mix, I get a very audible hum. If I disconnect the sat cable from the sat receiver it will go away.
My amp owner's guide says to install a 75ohm ground loop isolator. Will installing the ISO-MAX CATV-compatible "Hum-Stopping" Ground Loop Isolator from the POLK website, eliminate this? I've tried some cheaper items that did not work.
Thanks for any help!
Bryan Miller
Athens, Alabama
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited September 2004
    Hello Bryan,
    I believe you sent this question to our regular customer service email system, correct? If so, did my reply help?
    Regards, Ken
  • bamamusicfan
    Yes. Thanks!
    Bryan Miller
    Huntsville, Alabama
  • Tour2ma
    Tour2ma Posts: 10,177
    edited October 2004
    Mind sharing a little of the info on the fix and the results???
    More later,
    Tour...
    Vox Copuli
