polishing LSI9/LsiC
Howdy all!
I am curious what you Lsi owners use to polish the black on the Lsi lineup or Lsi9/Lsic?
I have some Meguiar's Ultimate Polish, I tried a VERY small spot on the bottom. wasn't to happy with the finish. mine are not that bad just want to clean them up. I usually just wipe them down with a Microfiber towel
One more question. on the Ebony Lsi does anybody use something for the panels too?
Any recommendations are much appreciated!
THANKS!
Cheers!
Polk Lsi9
Polk LsiC
Polk Fxi3
Pioneer SC-1222
Parasound 1200 II w/ Kimber Kable HERO + 4TC
SVS PB12-NSD (Bash)
PS4
Sharp Aquos 55"
"If your BOLD enough to try it,
your BOLD enough to make it happen"
  • warren
    warren Posts: 756
    Clean wood panels with furniture polish and a soft cloth. Do not use furniture polish on black gloss veneer.
    Clean black gloss veneer with a damp cloth.
    Some final words,
    "If you keep banging your head against the wall,
    you're going to have headaches."
    Warren
  • Roger that on the furniture polish.
    How about getting the scratches/swirls out on the black gloss?
    Cheers!!
    Polk Lsi9
    Polk LsiC
    Polk Fxi3
    Pioneer SC-1222
    SVS PB12-NSD (Bash)
    PS4
    Sharp Aquos 55"
    pitdogg2 Posts: 27,072
    edited April 2016
    Yea I don't think furniture polish is a good idea many are silicone based and just attract dirt and dust. On my real wood SDA's I use Johnston's paste wax. Rub it on with soft cloth let dry a little and rub off with clean towels. One trick I remember from all the woods classes taken in high school except we used 000 steel wool there. I did use steel wool to apply on mine but you be the judge whether it would work on your panels. With the gloss black I'd probably stay with soft cloth.
  • Mikey081057
    Mikey081057 Posts: 7,127
    For the Lacquer ... Gibson guitar polish... get it on amazon or at guitar center
    Garage | Polk Monitor 5B's
  • quicksilvergts
    quicksilvergts Posts: 274
    edited April 2016
    Mikey, anything local maybe? We have one music store in town I'll check that one out tomorrow.
    My main concern is the scratches/swirl marks and such.
    Thanks all!
    Cheers!
    Polk Lsi9
    Polk LsiC
    Polk Fxi3
    Pioneer SC-1222
    SVS PB12-NSD (Bash)
    PS4
    Sharp Aquos 55"
    F1nut Posts: 51,798
    You don't need polish, waste of money. Wipe with soft damp cloth, done.
    That gloss black isn't lacquer, IIRC. I believe it's plastic.
  • So I just keep truckin it with scratches swirl marks on it? Lol. I do use a damp microfiber cloth along with a dry one when routinely cleaning.
    Cheers !
    Polk Lsi9
    Polk LsiC
    Polk Fxi3
    Pioneer SC-1222
    SVS PB12-NSD (Bash)
    PS4
    Sharp Aquos 55"
    Polk Lsi9
    Polk LsiC
    Polk Fxi3
    Pioneer SC-1222
    SVS PB12-NSD (Bash)
    PS4
    Sharp Aquos 55"
    F1nut Posts: 51,798
    edited April 2016
    There are products that are supposed to remove light scratches from plastics. Like I said though, I think it is plastic, so best check with Polk first.
    That should be fine.
  • Joey_V
    Joey_V Posts: 8,600
    I dont think polish will remove surface scratches unless you are removing a layer to even out the scratches or adding a layer to the scratches even out the surface.
  • steveinaz
    steveinaz Posts: 19,545
    edited April 2016
    I used to have a black Honda Magna that drove me nuts with "spider webbing" like that. Now, try this on a hidden surface first--but I found the only thing that worked was clear coat sealant. I'd lay the sealant first, then wax and I had a deep shine. You could also try polishes for motorcycle/atv/windscreen plastics.
  • Thanks you for the info and suggestions eveybody!
    I tried calling Polk but unfortunately it's to late when I get home. I will try next week and also give those recommendations a go.
    Thanks again!!!
    Cheers!!
    Richard
    Polk Lsi9
    Polk LsiC
    Polk Fxi3
    Pioneer SC-1222
    SVS PB12-NSD (Bash)
    PS4
    Sharp Aquos 55"
  • westmassguy
    westmassguy Posts: 6,850
    I've used "Mothers" Plastic Polish in the past. Works well on colored plastics.
    http://www.mothers.com/02_products/06208.html#&slider1=19
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • Great! I am going to Walmart later for groceries. I will pick some up or stop at auto zone thanks!
    Cheers!
    Polk Lsi9
    Polk LsiC
    Polk Fxi3
    Pioneer SC-1222
    SVS PB12-NSD (Bash)
    PS4
    Sharp Aquos 55"
