LS90 crossover frequencies and mods
I have a set of LS90 speakers. I have upgraded to the revised crossover. Does anyone know the frequencies of the crossover? All the calculators I tried don't fit the design.
I have put in mills resistors and Mundorf Supreme caps, lined inside of cabinets,spikes. My friend has B&W 683 speakers and I put Mundorf silver gold and oil caps and Mundorf resistors in. Expensive about $1000 for them. They have WAY more detail than mine. My speakers sound nowhere near as good as his.
My plans were to build the crossover like the VR3 ones on here. If I use Mundorf silver gold oil caps in place of the Clarity Cap will I get the same level of detail as his 683's? Should I be looking at a different crossover design or different speakers? Very little info out there on these speakers. My biggest thing I am looking for is the high end details.
Mike
  • thsmith
    thsmith Posts: 6,082
    I dont think you want to use oil caps in your speakers but I could be wrong. Here is a link to the upgrades I performed on my LS90s.
    http://forum.polkaudio.com/discussion/141407/ls90-tweaks-and-upgrades/p1
    pitdogg2 Posts: 24,587
    Painting a peach to look like an apple will not make it taste like an apple.
  • kc9hqv
    kc9hqv Posts: 3
    I am going to order some of the parts for the rebuild I will order the caps later. BTW the $1000 for the caps was for all of them for both B&W speakers. The 10uF were $250 each. I did everything to my speakers as was done to yours.
  • mopar paul
    mopar paul Posts: 277
    B&W are "brighter" than many speakers and while some consider that to be detail, it really isn't the same.
    I've heard people say the sl2000 tweeter has more detail when all it has is a frequency peak.
    I don't think what your trying to achieve is entirely possible.
    Are you using the same equipment for your comparisons?
  • Nightfall
    Nightfall Posts: 10,073
    edited April 2016
    Buy a pair of Klipsch, swap all your gear for Emotiva, and replace all cables with Monoprice. You'll be rolling in high end frequencies.
    You're not going to get what you're looking for with the LS90's. If you like the B&W's buy a pair of B&W's.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • kc9hqv
    kc9hqv Posts: 3
    I replaced just the resistors. Took out the Mills and put in Mundorf. The highs were more natural sounding. I tried both my Carver 55X amp and Emotiva XPA5. The Carver was better sounding. More bass, highs were not as bright as the XPA5.
    Anyone else ever try Mundorf vs Mills resistors?
  • westmassguy
    westmassguy Posts: 6,850
    kc9hqv wrote: »
    Mills tend to be a little warmer. The Mundorf MOX are longer, and sometimes difficult to fit on the board. Both are much better than the original Sand-Cast Resistors.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • K_M
    K_M Posts: 1,627
    I would go the "Different Speaker" route.
    If you prefer the sound of his speakers, that much over yours, you obviously have a preference for the B+W sound.
    tonyb Posts: 32,906
    Agreed, there is only so much you can do to enhance a speakers design and build. Maybe you just prefer the B&W sound, buy some and see.
