Inductors for sda-srs upgrade
I need to know which Jantzen inductors should be used for my sda-srs..values are .4mh, 2.75mh and .7mh. I am looking at the parts express site. The 16mh I am buying from Solen
thanks, Bill
Best Answers
  • gimpod
    gimpod Posts: 1,793
    edited March 2016 Answer ✓
    wrich22a wrote: »
    thanks, Bill
    @wrich22a The chart above is for the 4th & 5th generation SDA only!, Yours are 3rd gen.
    You'll need to measure the wire gauge & DCR of your inductors as theses value are not stated in the schematics. Get these wrong and you'll most likely change the speakers voicing most likely in a bad way.
    Here is a link on how to measure inductor DCR and no your multimeter is not accurate enough.
    Inductor DCR Insanity For Sdas
  • wrich22a
    wrich22a Posts: 7
    Answer ✓
    Thanks for the info. I wonder if anyone has done the sda-srs , I was involved with this
    about 8 years ago. I modified my SDA-SRS's with everything back then. except the inductors. I just retired and am trying to catch up with my unfinished projects.
  • Schurkey
    Schurkey Posts: 2,122
    Answer ✓
    Not unless you count used circuit boards that have had all the previous components removed.
    The Gimpod aftermarket circuit boards would be for later-generation speakers.
    I suppose you could draw up the circuit, and have boards made. Not my first choice, however.
Answers
