Inductors for sda-srs upgrade
wrich22a
I need to know which Jantzen inductors should be used for my sda-srs..values are .4mh, 2.75mh and .7mh. I am looking at the parts express site. The 16mh I am buying from Solen
thanks, Bill
thanks, Bill
Best Answers
thanks, Bill
@wrich22a The chart above is for the 4th & 5th generation SDA only!, Yours are 3rd gen.
You'll need to measure the wire gauge & DCR of your inductors as theses value are not stated in the schematics. Get these wrong and you'll most likely change the speakers voicing most likely in a bad way.
Here is a link on how to measure inductor DCR and no your multimeter is not accurate enough.
Inductor DCR Insanity For Sdas“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
Thanks for the info. I wonder if anyone has done the sda-srs , I was involved with this
about 8 years ago. I modified my SDA-SRS's with everything back then. except the inductors. I just retired and am trying to catch up with my unfinished projects. -
Not unless you count used circuit boards that have had all the previous components removed.
The Gimpod aftermarket circuit boards would be for later-generation speakers.
I suppose you could draw up the circuit, and have boards made. Not my first choice, however.
Answers
Is there a bare circuit board available?
Thanks, Bill
