702 Wall Distance Switch
I'm not clear on which way the switch should go. It says " Set the switch accordingly, <2' (60 cm) or >2' (60 cm)"
I have a 5.1 setup with the surrounds (702's) on the back wall with the couch on that wall. My right surround is closer then 2' feet from the side wall but my left surround is open on both sides.
So which way do I set the right surround <2' or >2' and is there a middle position if you're not close to a wall or do I set the left the other way? I'm so confused!
Anaheim Hills CA,
>2 means less then 2 feet from the wall and <2 means greater then 2 feet. I hope I'm right lol
Full 5 channel set of Polk Audio
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Mits WD-82842 82" DLP 3DTV
Denon AVR-3313CI Receiver
Emotiva stealth DC-1
Emotiva XPA-2/Fronts XPA-3 Center-surrounds
Oppo 103
Loving the new Family!
Also it's just a switch ment to help with booming bass if there a close wall next to the speaker. So if it sounds boom and not tight and clean then flip the switch.
Try some heavy bass music to test.Full 5 channel set of Polk Audio
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Oppo 103
That's what I thought but wanted to make sure...Thanks!
Anaheim Hills CA,
2 Channel: Rogue RP-5 / WireWorld Electra power cord / Marantz TT-15S1/ Ortofon - Quintet Black MC / Marantz NA8005 DAC / W4S mAmp's / Synology DS 216+ll-4TB / Polkaudio LSiM703 -
If the arrow is pointing to the right it means "greater than", if pointing to the left then "less than".
Sweiously? And all these years I thought the wider end of the arrow ment largerFull 5 channel set of Polk Audio
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Oppo 103
KennethSwauger wrote: »If the arrow is pointing to the right it means "greater than", if pointing to the left then "less than".
Hey Ken, Are they both the same because one of them does not have a sticker on the switch...Quality Control!
Anaheim Hills CA,
Yes, they are the same.
Thanks Ken!Anaheim Hills CA,
No, there is a Left and a Right
