702 Wall Distance Switch
gce
gce Posts: 2,158
I'm not clear on which way the switch should go. It says " Set the switch accordingly, <2' (60 cm) or >2' (60 cm)"
I have a 5.1 setup with the surrounds (702's) on the back wall with the couch on that wall. My right surround is closer then 2' feet from the side wall but my left surround is open on both sides.
So which way do I set the right surround <2' or >2' and is there a middle position if you're not close to a wall or do I set the left the other way? I'm so confused!
Anaheim Hills CA,
  • eclypse
    eclypse Posts: 595
    >2 means less then 2 feet from the wall and <2 means greater then 2 feet. I hope I'm right lol
    Full 5 channel set of Polk Audio
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Mits WD-82842 82" DLP 3DTV
    Denon AVR-3313CI Receiver
    Emotiva stealth DC-1
    Emotiva XPA-2/Fronts XPA-3 Center-surrounds
    Oppo 103
    Loving the new Family! :)
  • eclypse
    eclypse Posts: 595
    Also it's just a switch ment to help with booming bass if there a close wall next to the speaker. So if it sounds boom and not tight and clean then flip the switch.
    Try some heavy bass music to test.
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Oppo 103
  • gce
    gce Posts: 2,158
    eclypse wrote: »
    That's what I thought but wanted to make sure...Thanks! B)
    Anaheim Hills CA,
  • [Deleted User]
    [Deleted User] Posts: 7,598
    If the arrow is pointing to the right it means "greater than", if pointing to the left then "less than".
  • eclypse
    eclypse Posts: 595
    Sweiously? And all these years I thought the wider end of the arrow ment larger
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Oppo 103
  • gce
    gce Posts: 2,158
    Hey Ken, Are they both the same because one of them does not have a sticker on the switch...Quality Control! :p
    Anaheim Hills CA,
  • [Deleted User]
    Yes, they are the same.
  • gce
    gce Posts: 2,158
    Thanks Ken!
    Anaheim Hills CA,
  • afterburnt
    afterburnt Posts: 7,892
    No, there is a Left and a Right
