2.3 tl upgrades
After 2 years of ownership, and I should add much enjoyment, I'm moving forward with more upgrades. Initially these had blown tweets in top position so completed the recommended 198 upgrade. Obviously a huge improvement there. Switched to a low DCR iron core inductor, ERSE, unwound to around 16mH with audible improvement to bass. Finally got around to applying no-rez , which had been laying around for 2 years, behind stereo array section with mixed impressions. Only used 3"x length of stereo array section, but feel bass has suffered too much... need to check enclosure over but think I will reduce amount of no-rez?
Currently need guidance on crossover section. Weighing many comments regarding selection of components in the forums I believe the sonicap/mills recommendations would best suit my tastes. When ordering, the sonicap has all the required values but mills is not available in the 22.5 Ohm value but there is a 22.1 Ohm available. Has there been a discontinuation or is this within tolerance?
