Monitor 5s...different cross overs?
  • westmassguy
    westmassguy Posts: 6,850
    These are the T/S Parameters for the MW6502:
    MW 6502
    Fs: 44.0000 Hz (Free air resonance)
    Vas: 1.2360 ft^3 (Compliance volume)
    Qts: 0.2790 Total Q
    Qms: 1.9700 Mechanical Q
    Qes: 0.3250 Electrical Q
    Sd: 0.0130 M^2 (Piston area)
    Xmax: 3.1800 mm (Cone excursion, linear)
    Revc: 3.5200 ohms (DC resistance)
    Znom: 4.0000 ohms (Nominal impedance)
    Pmax: 35.0000 watts maximum rated power
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • Polkaguy58
    Polkaguy58 Posts: 352
    Thanks for the info, much appreciated !
  • Polkaguy58
    edited March 2016
    Everything's back together and I settled on keeping a pair of Monitor 5's, with 5 Jr crossovers and a stock pair of Jr's (with just a bit more stuffing).
    The Mortite did it's job and everthing sounds tight as a drum.
    Just for Jollies, I'm going ahead with my inverted 5 Jr project, using my leftover pair.
    I made a fiberglass patch for the tweeter hole, which will now be on the bottom.
    The active woofer will be on top and the passive in the middle position.
    I decided to mount jacks on the back side of the cabinets, so that I can add any tweeter array I wish and mount them to the top of the speakers.
    This way I can try out my Jensen horns, try a time align tweeter or maybe even a Lineum 360 degree film tweeter ?
  • Polkaguy58
    Polk 5 Jr's: "The Final Chapter".
    After putting them right, I just sold them off to a new Polk convert.
    It seems that motorcycle season is fast approaching and my time and money will be tied up in riding and tweaking my newest steed. (Suzuki Burgman 400)
    I'm totally happy with my system as it stands (5B's & 5Jr.s with a Cambridge Soundworks subwoofer) and will lay back on the speakers until next winter, when I get bored again.
  • codycatalist
    codycatalist Posts: 2,661
    What model cambridge do you have? I ended up wiring my 8 inch Harman kardon subwoofer to my monitor 5s to relieve the lower bass work. Sounds good but worried of how it may have changed the impedance of the ohm load and what that may do to my amp and speakers.
