Tweeter Q
kevhed72
kevhed72 Posts: 5,140
Do the rti and the RTiA series speakers use the same tweeters? Missing fronts to my HT setup which is all RTIa series and need a suitable replacement.....
  • [Deleted User]
    [Deleted User] Posts: 7,658
    They are very similar, sometimes it is the shape of the mounting face-plate that is different. For example the RTi12 uses the RD0691-1 tweeter and the RTiA9 uses the RD0697-1. For purposes of tonal balance and system matching they are the same.
    tonyb Posts: 33,072
    Missing tweeters ?? Somebody break in your joint in the middle of the night and steal them ? lol
  • motorhead43026
    motorhead43026 Posts: 4,009
    I think it was this guy.
    – Kevin Alfred Strom
  • kevhed72
    You guys are a riot
  • kevhed72
    Thanks Ken....
