Tweeter Q
Do the rti and the RTiA series speakers use the same tweeters? Missing fronts to my HT setup which is all RTIa series and need a suitable replacement.....
They are very similar, sometimes it is the shape of the mounting face-plate that is different. For example the RTi12 uses the RD0691-1 tweeter and the RTiA9 uses the RD0697-1. For purposes of tonal balance and system matching they are the same.
Missing tweeters ?? Somebody break in your joint in the middle of the night and steal them ? lolHT SYSTEM-
lsi 9's -
I think it was this guy.
Religion began when the first scoundrel met the first fool……….Voltaire. -
You guys are a riot
Thanks Ken....KennethSwauger wrote: »They are very similar, sometimes it is the shape of the mounting face-plate that is different. For example the RTi12 uses the RD0691-1 tweeter and the RTiA9 uses the RD0697-1. For purposes of tonal balance and system matching they are the same.
