Can I utilize this amp?
hochpt21
in Electronics
I may be able to get one of these from work.
Would I be able to somehow use this as a subwoofer amp??
Paul - call me later but short answer is yes but...."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
Crest used to be one of the best in pro audio gear, I've been out of the loop on the pro gear for about 6 years, not really familiar with this particular CA model of power amp. Looks like it's not rated to run below 4 ohms,hmm. Maybe some other pro gearheads here can chime in.
EndersShadow wrote: »Paul - call me later but short answer is yes but....
Why do I feel like that "but...." is going to be a pain in my 'b.utt'.
JK...I'll give you a call later tonight.
PS...yes, the work b.utt is not allowed.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A -
PS here is the link to the manfacture specs
http://www.peaveycommercialaudio.com/products.cfm/Power-Amplifiers/CM-Series/CM-2204"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
^^ just looked that up myself.
Unless that's a misprint, that's the first time I've seen an amps spec that lists the 4 ohm rating LESS than the 8 ohm.HT SYSTEM-
lsi 9's -
Yeah I read that two or three times just to make sure.
We chatted last night and I think this will work for what he's looking at.
He's gonna be building fairly large 6+ cubic foot sealed boxes in a folded horn design potentially (Bill Fitzpatrick tuba sub) and that design doesnt need a lot of wattage to get stupid loud.
He's aware hes going to need a high pass/subsonic filter in the mix to keep the driver from unloading super low, but in his case he has the room for super large ported boxes, so he's should be good.
Now he just needs to marry that design in WinISD to a driver thats suitable. He will want to check out the models on 8 ohm DVC & 4 ohm DVC subs (each VC wired to its own channel) and 4 ohm VC subs to see which works best."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
@EndersShadow
Thanks for the conversation last night. I won't know for a couple months if I can score one, and I'll check into the things you mentioned in the meantime.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A -
@EndersShadow
No worries. Do your due dilligence beforehand, that only costs you your time
. "....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
