Can I utilize this amp?
I may be able to get one of these from work.
Would I be able to somehow use this as a subwoofer amp??
FA02518C-9A83-485E-B034-1E06D2474206_zpsnf8xyfz1.jpg?1455742952799&1455742955469&1455742959707&1455742961546
F9898C42-DF6E-4AD4-950D-56C01A03B7CC_zpsilbfln3q.jpg?1455742952799&1455742955469&1455742959707&1455742961546&1455742967515&1455742968322
    EndersShadow Posts: 17,705
    edited February 2016
    Paul - call me later but short answer is yes but....
  • Polkie2009
    Polkie2009 Posts: 3,834
    Crest used to be one of the best in pro audio gear, I've been out of the loop on the pro gear for about 6 years, not really familiar with this particular CA model of power amp. Looks like it's not rated to run below 4 ohms,hmm. Maybe some other pro gearheads here can chime in.
  • hochpt21
    hochpt21 Posts: 5,423
    Why do I feel like that "but...." is going to be a pain in my 'b.utt'. :p
    JK...I'll give you a call later tonight.
    PS...yes, the work b.utt is not allowed.
  • oldrocker
    oldrocker Posts: 2,590
    ^^ just looked that up myself.
    tonyb Posts: 33,072
    Unless that's a misprint, that's the first time I've seen an amps spec that lists the 4 ohm rating LESS than the 8 ohm.
    tonyb wrote: »
    Yeah I read that two or three times just to make sure.
    We chatted last night and I think this will work for what he's looking at.
    He's gonna be building fairly large 6+ cubic foot sealed boxes in a folded horn design potentially (Bill Fitzpatrick tuba sub) and that design doesnt need a lot of wattage to get stupid loud.
    He's aware hes going to need a high pass/subsonic filter in the mix to keep the driver from unloading super low, but in his case he has the room for super large ported boxes, so he's should be good.
    Now he just needs to marry that design in WinISD to a driver thats suitable. He will want to check out the models on 8 ohm DVC & 4 ohm DVC subs (each VC wired to its own channel) and 4 ohm VC subs to see which works best.
  • hochpt21
    @EndersShadow
    Thanks for the conversation last night. I won't know for a couple months if I can score one, and I'll check into the things you mentioned in the meantime.
    hochpt21 wrote: »
    @EndersShadow
    No worries. Do your due dilligence beforehand, that only costs you your time :wink:.
