2.3TL Rebuild Starts Now
245678
  • machone
    machone Posts: 1,559
    When I get them located I will add the spikes. Right now the sliders work great for moving them around but I am sure they are bad for sound.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • Mike Reeter
    Mike Reeter Posts: 4,315
    Looks as if you are doing very nice work on the old Classics, you will have a Reference pair when you are done!
  • machone
    I finished the mechanical mods on the second speaker and must say that these speakers are amazing and I have not touched the xovers.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • machone
    I listened again last night after Larry's rings, black hole 5, and dynamat mods. I had several driver gaskets that were torn or folded over so I replaced them and I replaced the tweeter gaskets. Note that I already upgraded the tweeters to 198's.
    Now the push test is excellent.
    Imaging is much improved.
    Bass is tighter with better dynamics.
    Overall soundfield is wider, taller and deeper.
    Vocals sound so natural.
    They are very musical.
    I am very pleased with their sound and look forward to upgrading the crossovers, jumpers and sda cable.
    Thanks to everyone for your guidance and advice.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    F1nut Posts: 51,782
    Ya ain't heard nothin' yet.
  • ^^^^^ :p
    Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
    Polk SDA2btl highly modded
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
  • Mike Reeter
    machone wrote: »
    When installing new driver gaskets you will need to go back and re-torque the mounting screws as the new gaskets will compress over time.
  • machone
    Thanks Mike.
    I have been checking and re-torquing them as needed. :)
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • machone
    I see that there are several 16mH sub-base inductor choices for the 2.3TL's.
    1. Solen makes them up to a (whopping 10ga giant (.56 DCR) for a lot of money @ $170 each). I think DK used these.
    2. Special order Janzten c-coil 14 awg (.16 DCR) @ $70 each. I think vr3 uses these.
    3. Erse makes a steel core 16 awg 17mH (.52 DCR) @ $40 each that I can send to westmassguy to unwind to 16mH. The Erse is rated at 500 watts but 2.3TL's are rated at 750 watts. Is this a problem?
    What do you guys recommend?
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • I used the Erse super Q as suggested by Dave. This added punch to the lower bass, however be warned adding a lower DCR inductor will lower the impedance in certain situations. Make sure you have an amp that can handle a 4 or even at times 2 ohm load. I do like the way my SDAs sound with the Erse inductors, really good bang for the buck IMHO.
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
  • You also mentioned the power handling capacity of the Erse at 500 watts I don't think you could drive them hard enough to saturate the inductors. Mabey another forum member will chime in on this topic with better experience.
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
  • westmassguy
    westmassguy Posts: 6,850
    The Inductor is only connected to the two dimensional woofers, and only carries signals below 150Hz. You're no where near saturating the coil.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • Thanks Dave!! I was hoping you would chime in.
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
  • westmassguy
    Anytime Brother
  • machone
    Thanks Dave
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • machone
    Hey guys,
    I you had plenty of flexibility on where you could place your equipment rack relative to your speakers; where would be the best place for SQ?
    - Most put the rack between the speakers but is this best? If I needed to push the speakers back close to the wall the rack would be in front of the speakers.
    - On a side wall away from the speakers? This would mean longer speaker cables.
    I am redesigning my listening room for the 2.3TL's and wanted to know what you think.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • Conradicles
    Conradicles Posts: 6,343
    Best place for an equipment rack is NOT between your speakers.
  • machone
    I get that.
    If the rack is to one side or the other the distance to the speakers is unequal. I assume everybody should use equal length cables. If so what is the best way to handle the extra length of the longer cable?
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • Schurkey
    Schurkey Posts: 2,122
    machone wrote: »
    ERSE will custom-unwind their inductors to your spec for $10 each, last time I asked them. That was something like two years ago. Price may have changed. Having ERSE do it will not cost extra for shipping two ways for westmassguy to do it.
    F1nut Posts: 51,782
    Putting your gear on an open rack between the speakers shouldn't be a problem.
    What is a problem are large solid entertainment center type pieces of furniture.
  • machone
    Can 2.3TLs use a dreadnought?
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • Mike Reeter
    edited February 2016
    machone wrote: »
    Yes, and recommended!
    Post edited by Mike Reeter on
  • machone
    I thought so.
    Thanks Mike
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • machone
    I am trying to plan the interconnect cable upgrade for my 2.3TLs. In the future I plan to add an isolation transformer per recommendations on this forum.
    Is it better to:
    1. Use Speakon connectors
    or
    2. Use an extra binding post
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • westmassguy
    SpeakONs
  • Listen to Westmassguy. He knows his stuff and is awesome to boot.
  • machone
    All crossover components ordered :)
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • machone
    I finally got my listening room rearranged. Most of the large pieces of furniture have been moved with only pegboard and smaller pieces to remaining. I am now able to move speakers anywhere on the wall.
    Finally wide open spaces and I can sit down! :)
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • Gunther16
    Gunther16 Posts: 243
    Nice, need a speaker selector?
