CRS+ TL project-half way there
Before i start. Thank You WMG David. I would have never attempted this without your help. I did all this in my kitchen & David guided me thru it with ease. NOTE: some of the pictures taken might have been taking before i made changes...
1st day-I gutted the cabinets. Installed Larry rings (talk about snug). Sealed cabinets. Dynamated woofers & passive.
2nd day-Position baffles (WMG invention) & install holes & remove. Mount crossover & position inductor away from crossover board & woofers. Install baffles again & put in Dacron. Mount binding cup. Run all wires to where they will live. Put tweeter & woofers back. Put passive radiator back in place. Test for air leaks. PurrFecto.
Everything fell right in place. I am only half way & plan on starting the other speaker tomorrow. I will take the steps i took on this speaker so i know the cabinets are sealed & i take my time. Thank you again David. I will not test till finished. After doing the push on passive test something tells me the bass is going to be unbelievable. When i did it seemed like it held steady & never came back. I enjoyed these before & this is a different level :)
Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
MIT BJC Cs1000p Polk Rotation
