Bottlehead Crack
No hate....only jealousy! Bitter....bitter jealousyWhere’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!!
There will be a longer delay in the build of the BAC. I think I've found the ribbons I needed to repair the Carver Silver Amazings.
I think all I really have left on the BAC is to touch up the plate drawing but by the end of the week the ribbons might be here.Aaron
Enabler Extraordinaire -
I can't believe how upset I am still that you knew of black sockets this whole time!!!!
Still haven't installed the speedball yet either. It's gonna be a long winter......Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
I bought a second set of black sockets to use with the Carver speakers. They don't go anywhere, serve no purpose, but I didn't want to miss the chance to cause you further angst.
Get on that speedball! It's the numero uno upgrade for that thing!Aaron
Alriiiiiight!
I populated the boards, just need to make the connection. Raking and a Bathroom rehab take precedence over doing a speedball.Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
What does it take to see some pics of the progress! I promise, no more 'choke' pics....;)
But I'll toss in the bath upgrade completion pic from several years back...lol
Some plumbing p o r n....it isn't a load bearing wall.
When we did the lighted lower level bath, I had to remove a winder to get the shower stall in. We owner completed the entire lighted lower level. The rest of the house was done by builder. We didn't like how they completed the lower level for the money.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
That a....copper colored stuff...tweeters?
And how did you get a picket fence in the top of your shower? That's creative!!!
Aaron
The fence was protesting the window entry....Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
SCompRacer wrote: »
I'll take a pic of my soon to be finished remodeled bathroom tonight for you.
That valve setup.....yeah.....I don't DIY stuff like that! Nice!Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
HA! Thanks! The wife called me a bum...lol Towards the end of completion, I decided not to shave until it was done.
Body wash nozzles are nice, but they are not water savers. To me it was easier to build the assembly on a frame and place it than build it in the wall. A manual valve switches between shower, shower/body wash, body wash, tub and flexible shower hose. I had plugged and pressurized it before closing wall. Glad I did cause one of the lug tee's had a bad casting, a pinhole opened up.
Post your progress!Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
On a more relevant subject, I ordered a couple Sonicap Platinums to replace my Solen coupling caps in the Bottlehead Eros. Per Jeff's suggestion, went with a .33uf instead of 1uf or .47uf. Corner frequency calculated at ~2Hz.
As they say at the V Cap Coupling Calculator page, "The more material in the signal path, well, you know where this is going... the less transparent the signal becomes. When it comes to output coupling caps, less is more, as long as you've achieved a reasonable -3db point."Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
On to further Crack changes - get the 6.3v adapter from the Lowther_Club (didn't find it on dbay or fbay...something in between) to go from the 12AU7 to a 6SN7. It'll take three or four weeks to get here from China but it works perfectly. Don't forget to get a 6SN7 tube from somewhere also.
Horry bratcrap! Nice....very very nice!Aaron
I don't know how to use Google for this...
Send linky!Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
This is exactly what I bought.
ebay.com/itm/6V-6-3V-6SN7-6SL7-to-12AU7-12AX7-tube-adapter-socket-converter-one-piece-/151638849047?hash=item234e613617:g:C5UAAOxycERRk0g9Aaron
So......i have an announcement to make.....
My speedball...................is still sidelined due to completely forgetting/no time/haven't listened to headphones in close to 2 months/get off my back arron/slash.
Where the fudge is this "Big A$$ Crack Build"???!!!???!!!
Even by now, i;d at least have the shipping box opened...Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
The BAC is right next to your speedball!!
Don't use that 6SN7 adapter unless the speedball is installed.Aaron
BAH!......touchéWhere’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!!
This all sounds illegal.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
12BH7's and 12BH7a's are another nice tube to try in the crack...if you have the speedball installed.
BAC is closer. I found another project to finish and prototype a plate with and assuming I designed that correctly I'll move onto the BAC.Aaron
I'm so excited! Love that stuff, Mr. Hi-Tech. Can it do walnut?Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
Atta Boy!
Whats the half life of metal? Hopefully, you get it done before you have to worry about that.
Are you painting the plate? I can't remember.
What are you changing for the BAC? Volume pot, exotic caps, black tube socket....what else? Obviously making it twice the size...
Hey experienced Bottlehead users/modders. I picked up an old Bottlehead Foreplay with the upgrade to 12 step attenuators. Apparently, this is a known thing but there is a significant crackle when moving between steps, I read that installing higher end volume pots or better (24 step?) attenuators will help alleviate this.
Couple questions
1. Is this particularly complicated or a matter of desolder/solder - does anyone know?
2. Suggestions for a good brand / part (that won't also make a $225 Foreplay a $350 Foreplay)?
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Sony S9000ES CD/DVD/SACD
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
Nice unit!! Flip it over and give us a pick of it's bottom...I love bottoms....snicker....he said bottoms...Aaron
Atta Boy!
I am going to paint the plate - heated black hammered. Charging? hmmm....if you live in California 1.5 BILLION!!!Aaron
WIll Do! Listening to that bad boy right now! For the money, it's shockingly good.
Post edited by MrBuhl onVA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
What do the knobs do? I'm going to guess the middle one selects the input? And then one side is volume for left and the other volume for right?Aaron
Atta Boy!
Can I try this again? Changing...not charging...good grief...
I'm going to use an 6SN7 in place of the 12AU7 so in go the nice black (I would never rub in the fact that I have black sockets) 8 pin sockets.
Power supply caps will be changed. The first two are just bigger electrolytic and the final is a 220 uf solen cap. I'll remove one of the resistors and use a choke.
I'll replace the diodes with better ones. Output caps will be Clarity cap PX's tipped with Clarity MR series 1uf.
Volume pot is a gold point. RCA inputs are Vampire.
Moved some things around a bit. Volume will be on the front left, headphone jack in the front center and on/off on front right.
I'll post pictures as I make progress.
Aaron
SCompRacer wrote: »I'm so excited! Love that stuff, Mr. Hi-Tech. Can it do walnut?
I think we have a bit more power than would be required for walnut!! Flames - smoke....POOF. No more walnut...
Aaron
You are correct - center is for input selection, left and right are left/right volume.VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
