SDA-CRS/CRS+ Something Different
Ever since I acquired my CRS+s, I've been amazed at what these little boxes can do. I had
done an initial, cost constrained re-cap on the crossovers, and all the usual upgrades we do. After acquiring my 2As, and doing all the upgrades on them as well, it occurred to me that one upgrade was not really possible with the CRSs, Damping. From the factory, all they came with, was a wad of Dacron on the side where the crossover is located, and that's it. Nearly all the other SDAs, Monitors, and RTAs had rolls of Dacron behind the woofers, extending all the way to the top of the cabinets in most cases. As part of the cabinet upgrades, we remove the Dacron, and install strips of BH5, No Rez, or Sonic Barrier on the rear wall, and re-install and re-position the Dacron. You can't do that with the CRSs. The best you can do is cut and fit small pieces on BH5 et al. and stuff the Dacron back in one side. Not the ideal solution. I had been tossing around a few scenarios for adding additional damping material to mimic what we do with all the other vintage Polks.
My 1st thought was cutting and fitting BH5 on the back wall, adding a doughnut shaped piece of BH5 to the back of the Passive Radiator, then stretching and tacking a double layer of Bonded Dacron directly behind the woofers. The problem with that is the possibility of over damping the enclosure and the fact that we never install Dacron anywhere near the Passive Radiator. My second idea was to create some type of baffle that would mount behind each woofer. I could attach BH5 to the fronts, which would face the back of the woofers, and it would give me a gap where Dacron Batting could be inserted. The baffles would have to be large enough to actually do something, i.e. catch some of the mid frequency back waves from the woofers, but also be small enough not to block, interfere or constrain the larger sound and pressure waves. The intent after all, is to clean up the midrange handled by the woofers, without sucking the life out of the music.
In the interim, my friend Darryl @voltz had acquired a pair of CRS+s, and asked if I would do his crossovers for him. I agreed, and tossed the idea of experimenting with the damping, being a trooper, he said sure. I had planned on rebuilding my crossovers at the same time. We had agreed to do Sonicaps, Mills Resistors, TL Modification, and replace both Lo-Pass inductors with Jantzens. I'd also be supplying Erse Inductors for the Sub Bass Drive, Cardas Binding Posts, and reworking the Interconnect with SpeakONs on his. Darryl supplied me with the same Flat Oval Cable he would be using for the speakers. An 800VA Dreadnaught would also be constructed.
The Crossovers were straight forward. The spool inductors were eliminated; new mounting plates were made, and secured with stainless hex head cap screws and nylon standoffs. The new Jantzen, and Erse Inductors were unwound to the exact values needed. All components were attached with 3M VHB tape, and Nylon Wire ties. SpeakON connectors and Cardas posts were installed on the Binding Post Cups. Darryl wanted the deluxe Dreadnaught, with Copper Shielding, Dynamat, and cast SpeakONs.
For Damping, I decided to go with the baffles. I cut 7" X 7" pieces of 3/16" Masonite. These were glued and bolted to 5" X 5" steel angles. The Masonite was sealed with lacquer, and BH5 applied to the face. I purchased some 1" Bonded Dacron, and cut two 19" X 19" sections, and folded them in half.
Do to circumstances; I was unable to complete my own Crossovers, so I decided to install Darryl’s Crossovers, one set of dampeners and the Dacron in my cabinets for a test run. This would allow me to hear the difference between the stock, and new damping treatment.
I installed the crossovers, and the new Damping Baffles in the left speaker about 5" back from the woofer openings (I believe Darryl eventually placed them 6" back). The Bonded Dacron was installed in the left cabinet, and the stock Dacron in the right. I connected the new Dreadnaught, and fired everything up. I let them breath for a while before playing some familiar tracks. The Stereo Image was dead center, a good sign. I immediately noticed a smoother sound quality from the left speaker. The right speaker sounded as if it were shouting during certain passages. Keep in mind, my woofers were original, and my RDO-198-1 Tweeters had already been broken in. Obviously all the new components needed a good deal of burn-in, but overall, I was very pleased with the improvements. Top to bottom, the left sounded very well balanced, while the right speaker sounded off, more forward in comparison. When compared to my 2As, the left speaker was very similar, while the right, not so much. Although my concern for over-damping the enclosure was well founded, I believe they sound just about right. You can experiment with the alternatives to BH5. No Rez, and Sonic Barrier, may well react differently. I know Sonic Barrier has 5 different thicknesses available, so you can play with the amount of damping. My goal was to duplicate as closely as possible, the additional damping we install in other upgraded vintage Polk cabinets. I believe that goal was met.
There is one caveat; severe space constraints. If you're using the original Spool Inductors as mounts for the Crossovers, Tony's @gimpod boards, or custom Air Core Inductors, the baffles may not fit without some creative rearranging.
Home Theater/2 Channel:
dhsspeakerservice.com/
  • voltz
    voltz Posts: 5,384
    1st off I have to say Thank You Dave!! B)
    I didn't want to skimp on anything for this chance to upgrade this Vintage Polks, and I had Dave use Sonicaps all around and make me a Deluxe Dreadnaught as I did not want to have any regrets later.
    But the Damping Boards really took it to a new level and after doing one speaker only and listening between the two I found the Damping boards to give a cleaner sound tighter sound especially with the Mids and I highly recommend anyone with CRS's to give them a try as if you dont like them there easy to remove but you won't ;)
    Did a lot of comparison with my Monitor 10's & Polk 703's and the wilder sound field SDA effect just makes the other speakers fall short and seem plain sounding, but with my 10's I found I was even missing some sound ambient sounds from certain songs like Steely Dan "Black cow" and others that the cross talk on the 10's eliminates but I could hear with my CRS +'s as ambient sound was more isolated off to the left where I could pay attention to it. That is the SDA effect for ya which Dave can explain better the me.
    Fist rate job again from Dave and you should see my smile every time I listen to my NEW Special Edition CRS+'s!! He really knock this one out of the park! Kudos Brother!
    Darryl
  • voltz
    voltz Posts: 5,384
  • westmassguy
    westmassguy Posts: 6,850
    Thank you Brother.
  • MrBuhl
    MrBuhl Posts: 2,419
    damned creative - and pretty cool stuff - congrats guys!
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • voltz
    voltz Posts: 5,384
    BTW I bought "The Who's" vinyl box set so I been listening to them last couple of hours on the CRS's & the LP "Who's Next" was Stunning and I had to play it twice in a row :p
  • vmaxer
    vmaxer Posts: 5,124
    Very nice.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • ptrooper
    ptrooper Posts: 739
    edited October 2015
    Love it , :) Great idea........I would love to own a set of crs+
    VR3 SDA SRS 1.2TL Duelund Monoliths+VR31000va Dreadnaught +VR3 MM2 SDA cable, <3 ,Lumin u2x ,<-sfp fibre <-LHYas8 Pro+ Switch,Transparent Reference MM2 xlr,power and speaker cables.FTA Sinope SE usb.40 Amp power line for amp with earth stake&Faraday shield ,20 Amp power line for digital equipment ->shunyata 8 venom power board...Working on it!
  • westmassguy
    Thanks guys.
  • leftwinger57
    leftwinger57 Posts: 2,917
    Dave, pretty amazing work and doing kind of an experiment w/ a customers speaker who of course gave permission. Far be it for me to say anything but when I did my 2Bs w/ the BH-5 w/ the spaced 3" strips from the top of the cabinet to the bottoms of the mid woofers the sound was so dramatically changed I was not sure I liked the change. That I had to get used to and I did and left it in. That stuff does work as advertised. to much and you'll have a real lined monkey coffin. Can't wait for you know what....
  • westmassguy
    Thanks Lew. BH5 was originally designed to dampen cabinet resonances. We use it to absorb/reduce midrange reflections, which would normally bounce around, and make their way back out through the cone, causing a loss of detail. The other damping materials I listed will have different absorption qualities. I've used Sonic Barrier quite a bit, and the thickest is comparable to BH5. If less damping is required, then one of the thinner versions could be used.
    I'm working on your "you know what" today.
  • voltz
    voltz Posts: 5,384
    The Bass is so good I have not hooked up my sub yet! especially with Peter Gabriel's "Sledgehammer" or Don Henley's "Dirty Laundry".
  • westmassguy
    voltz wrote: »
    Only going to get better
  • cortico
    cortico Posts: 593
    Very nice westmassguy always read with attention your threads. Love mine, I Installed the RDOs, disconected the dimensional tweeters, new armacell tape/nuts around drivers, but haven't recapped it yet. I have to finish recapping an integrated amp I got to my monitor 5 and then I'll get my hands on it...
  • westmassguy
    cortico wrote: »
    Thanks. Your CRSs would benefit as well.
  • drumminman
    drumminman Posts: 3,396
    Very nice Dave. The CRS+ are tough to work with due to the lack of space. When I did mine I put I mounted the Xovers on the floor of the cabinet to orient the inductors away from the magnetic fields of the MW magnets. I then put BH5 on the back wall and reinstalled the original poly foam. Your idea is interesting and If I decide to go back in mine I may try it.
  • westmassguy
    drumminman wrote: »
    Thanks drumminman. If you decide to revisit them, the top of the cabinet may be the only other location for the crossovers. It should be even farther away from the woofer magnets as well.
  • prosuite
    Killer. Any chance you will rebuild my crossovers for me? I have CRS ans 2.3's.
    Pm me.
    txcoastal1 Posts: 13,520
    Dave is a great cat
    Now Carrying Gimpod's Custom SDA Circuit Boards
  • littlewoodboats
    With the reduced room of the smaller cabintes I have always wondered what the downside might be to mounting the crossover outside the cabinet somewhere. Could they be placed on the back of the cabinets? Would there be any benefit?
  • westmassguy
    Not that I can see. They were designed with the displacement of the various parts taken into consideration.
  • littlewoodboats
    Thanks for the reply Dave. I was not clear in what I was trying to ask, sorry. I was thinking more of the magnetic fields you and drumminman mentioned above. Is there a guideline on what minimum distances should be observed? What is the effect that might be heard if they are placed to close?
  • westmassguy
    No clue what a safe distance is. I have to believe Polk mounted it in the upper corner to be clear of any magnetic fields. Inductors have their own magnetic field which is created by the signal passing through them. Any external magnetic field, or magnetic/ferrous metal will disrupt the Inductors field, and could cause distortion, and most certainly change the crossover frequency.
  • akajimmy
    akajimmy Posts: 50
    Those look like good mods. Can't wait to try them in my CRS.
  • westmassguy
    You'll be a happy camper.
    xschop Posts: 5,838
    The 3rd CRS build thread I've read thru today. Very ingenuitive solution to damping without interfering with the passive. About what total volumn was removed by those two barriers? Thanks WMG.
  • westmassguy
    xschop wrote: »
    Virtually nothing. The BH5 is 1.375" thick, but only displaces .25" of incompressible air. The Masonite is 3/8" thick. Each Baffle is 7" X 7".
    xschop Posts: 5,838
    Ok I see, the open-cell structure of foam. I've got a question you may be able to answer before I start my project.
    xschop Posts: 5,838
    WMG, sorry to bother you again, but what is the distance from the BH5 to the rear of the MW magnets approximately? I'm having my new boxes built next week and want to calculate the new depth with this mod permanently incorporated as internal bracing. Thanks, Rob.
  • westmassguy
    xschop wrote: »
    Not sure really. The steel angles were 6" as I recall. On mine, I placed the angle right against the back of the front baffle. I believe Darryl set his back a bit further.
    xschop Posts: 5,838
    WMG, can the Erse inductor be mounted right next to the board like in your 1st pic? Or will it interfere with the tweeter inductor coil?
    Ill be making a cover and installing board to back of Power Port platform....
