Monitor 10A tweeters.{"dim" sounding}
I recently purchased a pair of PA M10As. They're currently hooked up to a Kenwood KR-3600 receiver, and they sound great! Apart from one of the tweeters. I know the fuses are incorrect (a 3amp is currently in each unit), but one of the drivers isn't producing high fqz like the other. Its sort of "dim" sounding, not as clear or pronounced. Any particular reason for this lack in performance?
Best Answers
Answers
  • HzTweaker
    HzTweaker Posts: 1,008
    I took both Tweeters out of the cabinets (one at a time) and found that both were soldered to their wires (to try your suggestion). Is this correct?
  • HzTweaker
    Maybe they're wired out of phase.. I figured I had a potential project on my hands. I didn't know that it meant cleaning up somebodies mess..
  • HzTweaker
    Anyone have to share or know how I can obtain the drawings for the crossover/speaker wiring for the PA Monitor 10As?
  • HzTweaker
    Thanks guys, I'm going to start with putting correct fuses in each unit and check the wiring to make sure they're in phase with one another later today.
  • Nightfall
    Nightfall Posts: 10,083
    The 10As have Peerless Tweeters, which were soldered from the factory, as were many of the SL1000s after Peerless ceased production.
    Was it just the 10's that were soldered? Neither my 5's or RTA-12's are soldered. Haven't opened up my 4's yet.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • My 7A's are soldered.
  • As someone else mentioned, be sure to clean the fuse holder with contact cleaner, more than likely that will fix the problem (could be a blown fuse too). I strongly advise against desoldering the wire from the tweeter post. I did that to mine and the post fell off with no way to reattach it. Result: had to buy another Peerless tweeter. :(
    SDA SRS 2.3TL's
    SDA 2B TL's
  • westmassguy
    westmassguy Posts: 6,850
    Nightfall wrote: »
    A lot of the Peerless were soldered, I haven't seen one that wasn't. Some SL1000s were soldered, some not.
    As mentioned, use extreme caution when de-soldering and re-soldering.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • After the debacle of the post falling off, I installed female spade connectors to the wires.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • Be sure to heat sink when de-soldering and soldering.
    – Kevin Alfred Strom
    The creatures outside looked from pig to man, and from man to pig, and from pig to man again; but already it was impossible to say which was which.”……George Orwell-Animal Farm.
  • Nightfall
    edited October 2015
    Nightfall wrote: »
    Perhaps my speakers are the ones that have been changed then, that or Polk just did whatever they felt like doing on a particular day. Mine landed on a quick connect day. Sorry for the confusion OP.
    afterburnt wrote: »
  • HzTweaker
    So is there a way to test the crossover to find out if its the issue and not the tweeter itself?
  • HzTweaker
    Also I have a new Question Team (not sure if I should start a new post for this one. Pleas advise). So it mite be a silly question but should the serial numbers for a pair of speakers (M10As in question) match?
    F1nut Posts: 51,880
    No.
  • gdb
    gdb Posts: 6,012
    edited October 2015
    Why risk de-soldering at the terminals ? I'd sever the wire a few inches downstream, and then, strip/re-solder there.
  • gdb wrote: »
    Bingo
    SDA SRS 2.3TL's
    SDA 2B TL's
  • HzTweaker
    boston1450 wrote: »
    Not to often you will get the #'s consecutively even when they were bought new
    So whats common: L1234 L1235 or L3001 L4201(examples)?
  • HzTweaker
    boston1450 wrote: »
    I have no idea. I only know what i have seen on mine & other Monitor or SDA speakers. ...... (This has nothing to do with OP) This Vannila c r a p has got to go. You post stuff & it gets moved around & put where IT wants to put it. W T F
    Yeah Its wearied. I'm not exactly sure whats going on with my post and why they move around like they do.
  • boston1450
    boston1450 Posts: 7,758
    Yeah. I just got a REPORT you accepted some answer. Lol. The new system here is screwy
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • HzTweaker
    boston1450 wrote: »
    Right on. Well due to my availability this project is going on the back burner for a bit (I'm just glad I finally have a pair of these). But I'll still check in on the forum periodically. As soon as I start working on my pair of 10As I'll start a new post. Hopefully That one will be a little more organized lol.
    F1nut Posts: 51,880
    boston1450 wrote: »
    It's suppose to make you feel good when your post gets the special answer and check mark next to it. Since I'm not a millennial I find it annoying as hell.
  • westmassguy
    boston1450 wrote: »
    I used to get a gold star on my forehead in Kindergarten for having the right answer.
    Check marks make me all warm and fuzzy inside.
