Monitor 10A tweeters.{"dim" sounding}
HzTweaker
I recently purchased a pair of PA M10As. They're currently hooked up to a Kenwood KR-3600 receiver, and they sound great! Apart from one of the tweeters. I know the fuses are incorrect (a 3amp is currently in each unit), but one of the drivers isn't producing high fqz like the other. Its sort of "dim" sounding, not as clear or pronounced. Any particular reason for this lack in performance?
Best Answers
1a fast blow. Make sure its clean contact. Try changing tweeters around from one cabinet to the other-to see if it follows. If it follows its a bad tweet.Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
Make sure all speaker wires are on correct. As you know those xrossovers are old. Put glue around the woofer magnets to prevent Shifting Magnet from happening-is a cheap tip also. Report backRandy-Maine
by David WMG
There should be quick connects, somebody has had those open before.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
President of Club Polk -
The 10As have Peerless Tweeters, which were soldered from the factory, as were many of the SL1000s after Peerless ceased production.Home Theater/2 Channel:
dhsspeakerservice.com/ -
Not to often you will get the #'s consecutively even when they were bought newRandy-Maine
by David WMG
Don't obsess on serial numbers. They really don't mean anything anymore, with the exception of certain SDA models. As long as the driver compliment and crossovers are the same, you're good.Home Theater/2 Channel:
I have no idea. I only know what i have seen on mine & other Monitor or SDA speakers. ...... (This has nothing to do with OP) This Vannila c r a p has got to go. You post stuff & it gets moved around & put where IT wants to put it. W T FRandy-Maine
by David WMG
I just went through a crossover rebuild on my Polk 7A's, peerless. The tweeters are soldered on mine. I de-soldered and installed quick connects. I noticed the same dull sounding tweeter on one speaker. I swapped tweeters to rule out the crossovers, no change. Re-checked all the wiring, looked good. Replaced the tweeter with a used Peerless from a 7B, which fixed the problem. Most likely you have a bad tweeter. BTW both my tweeters ( including the bad one ) ohmed out at 7.6 & 7.8.
Larry's rings or Hurricane nuts from PE. Larry ring are made very good & when you tighten them up you "know" their in there good. Do the tweeter brackets & binding plate while your at it...... If your stock seal is not ripped - keep the gasket you have. They should be still good VS replacement. Thats how i did/do all mine & the ones im having WMG do nowRandy-Maine
by David WMG
Answers
I took both Tweeters out of the cabinets (one at a time) and found that both were soldered to their wires (to try your suggestion). Is this correct?2ch rig: Speakers: Magnepan LRS w/Magna Riser stands Preamplifier: Parasound P5 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
Standby: LSi9s with VR3's Fortress mods -
Maybe they're wired out of phase.. I figured I had a potential project on my hands. I didn't know that it meant cleaning up somebodies mess..2ch rig: Speakers: Magnepan LRS w/Magna Riser stands Preamplifier: Parasound P5 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
Anyone have to share or know how I can obtain the drawings for the crossover/speaker wiring for the PA Monitor 10As?2ch rig: Speakers: Magnepan LRS w/Magna Riser stands Preamplifier: Parasound P5 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
Thanks guys, I'm going to start with putting correct fuses in each unit and check the wiring to make sure they're in phase with one another later today.2ch rig: Speakers: Magnepan LRS w/Magna Riser stands Preamplifier: Parasound P5 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
westmassguy wrote: »The 10As have Peerless Tweeters, which were soldered from the factory, as were many of the SL1000s after Peerless ceased production.
Was it just the 10's that were soldered? Neither my 5's or RTA-12's are soldered. Haven't opened up my 4's yet.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
My 7A's are soldered.
As someone else mentioned, be sure to clean the fuse holder with contact cleaner, more than likely that will fix the problem (could be a blown fuse too). I strongly advise against desoldering the wire from the tweeter post. I did that to mine and the post fell off with no way to reattach it. Result: had to buy another Peerless tweeter.
SDA SRS 2.3TL's
SDA 2B TL's -
A lot of the Peerless were soldered, I haven't seen one that wasn't. Some SL1000s were soldered, some not.westmassguy wrote: »The 10As have Peerless Tweeters, which were soldered from the factory, as were many of the SL1000s after Peerless ceased production.
As mentioned, use extreme caution when de-soldering and re-soldering.
After the debacle of the post falling off, I installed female spade connectors to the wires.SDA SRS 2.3TL's
SDA 2B TL's -
Be sure to heat sink when de-soldering and soldering.Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
– Kevin Alfred Strom
The creatures outside looked from pig to man, and from man to pig, and from pig to man again; but already it was impossible to say which was which.”……George Orwell-Animal Farm. -
Perhaps my speakers are the ones that have been changed then, that or Polk just did whatever they felt like doing on a particular day. Mine landed on a quick connect day. Sorry for the confusion OP.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
So is there a way to test the crossover to find out if its the issue and not the tweeter itself?2ch rig: Speakers: Magnepan LRS w/Magna Riser stands Preamplifier: Parasound P5 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
Also I have a new Question Team (not sure if I should start a new post for this one. Pleas advise). So it mite be a silly question but should the serial numbers for a pair of speakers (M10As in question) match?2ch rig: Speakers: Magnepan LRS w/Magna Riser stands Preamplifier: Parasound P5 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
No.Political Correctness'.........defined
Why risk de-soldering at the terminals ? I'd sever the wire a few inches downstream, and then, strip/re-solder there.
BingoWhy risk de-soldering at the terminals ? I'd sever the wire a few inches downstream, and then, strip/re-solder there.
SDA SRS 2.3TL's
SDA 2B TL's -
boston1450 wrote: »Not to often you will get the #'s consecutively even when they were bought new
So whats common: L1234 L1235 or L3001 L4201(examples)?2ch rig: Speakers: Magnepan LRS w/Magna Riser stands Preamplifier: Parasound P5 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
boston1450 wrote: »I have no idea. I only know what i have seen on mine & other Monitor or SDA speakers. ...... (This has nothing to do with OP) This Vannila c r a p has got to go. You post stuff & it gets moved around & put where IT wants to put it. W T F
Yeah Its wearied. I'm not exactly sure whats going on with my post and why they move around like they do.2ch rig: Speakers: Magnepan LRS w/Magna Riser stands Preamplifier: Parasound P5 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
Yeah. I just got a REPORT you accepted some answer. Lol. The new system here is screwyRandy-Maine
by David WMG
boston1450 wrote: »Yeah. I just got a REPORT you accepted some answer. Lol. The new system here is screwy
Right on. Well due to my availability this project is going on the back burner for a bit (I'm just glad I finally have a pair of these). But I'll still check in on the forum periodically. As soon as I start working on my pair of 10As I'll start a new post. Hopefully That one will be a little more organized lol.2ch rig: Speakers: Magnepan LRS w/Magna Riser stands Preamplifier: Parasound P5 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
boston1450 wrote: »This Vannila c r a p has got to go. You post stuff & it gets moved around & put where IT wants to put it. W T F
It's suppose to make you feel good when your post gets the special answer and check mark next to it. Since I'm not a millennial I find it annoying as hell.Political Correctness'.........defined
I used to get a gold star on my forehead in Kindergarten for having the right answer.
Check marks make me all warm and fuzzy inside.Home Theater/2 Channel:
