Speaker cable question
Seems like a lot people in here like MIT cables. What improvements can I expect if moving from Signal Ultra speaker cable to MIT shotgun 1.3? Thanks.
    tonyb Posts: 33,065
    That's a big leap, not even comparable. The S1's are going to walk all over the Signals by no small margin.
    F1nut Posts: 51,674
    These demo reviews may give you some idea. The Shotgun 1.3 nets improvements in the bass verses the 3.3.
    http://forum.polkaudio.com/discussion/129583/mit-shotgun-s3-3-cable-demo-review-round-4/p1
    pitdogg2 Posts: 26,928
    edited September 2015
    brianle wrote: »
    A WHOLE LOT....Signal ultras are just two Canare 4s6 or 4s8 star quad's in flex wrap....
    by the way I use the Signal ultra's and just noticed that they are Canare because I just had to terminate and pulled back the flex to see just what it was inside. I just went ahead and ordered more Canare 4S11 as that is what my inter-connect SDA cable is made of so might as well match B)
  • madmax
    madmax Posts: 12,434
    I was amazed when I went from audioquest type 4 to MIT s3.
    Vinyl, the final frontier...
  • I went from MITs back to Audioquest Rocket 44s.
    msg Posts: 10,450
    I found Signal Ultras to be a little bright in a system I was testing, consisting of a B&K Reference 5 pre, Parasound amp, Squeezebox Touch, and some Monitor 10's. I was using Monoprice interconnects.
    I took advantage of the offers in the MIT Clearance Center and ordered a set of Shotgun S3 speaker cables and S3 interconnects. The cables you're looking at are even better than what I have.
    Bass noticeably more apparently, to the point that I had to zero the tone controls, whereas before I had the bass bumped a touch.
    Improved clarity, especially noticeable in the lack of congestion at higher listening levels.
    Improved articulation - instruments came in and out more cleanly.
    Echoey chick singer voices and instruments seemed to hang and fade beautifully.
    Those are some of the things I noticed during the first week. The only things I changed in the system during that time were the speaker cables and the IC's between the preamp and amp. I was a bit of a cable skeptic before that. I wouldn't call the improvements subtle.
  • brianle
    brianle Posts: 572
    what was the reason you went back?
  • I busted a spade off one of the wires and I haven't fixed it yet. :)
    These are monster cables. If setup doesn't lend to that...
  • marvda1
    marvda1 Posts: 4,936
    you could go a long time before you have to upgrade these.
    http://www.audiocircle.com/index.php?topic=137246.msg1460385;topicseen#new
    Puritan PSM156
  • brianle
    brianle Posts: 572
    DSkip wrote: »
    Brian, have you been in the cable game, or are you just curious about MIT?
    Nope. I've been using only Blue Jean and Signal cables :smiley:
  • BlueFox
    BlueFox Posts: 15,251
    What gear are you going to put it on? It might be overkill. I use the Shotgun S1.3 XLR interconnects in my HT, and they work great. They used to be in my stereo, and were a huge step up from the Kimber Kable Heros XLR they replaced.
  • brianle
    brianle Posts: 572
    Thanks! This is going to be on my main rig: Ayon Tritton 3 + Dynaudio C4. I currently use Harmonic Tech Magic Link 2 from the Benchmark DAC to the Ayon.
  • marvda1
    how much are you planning to spend on cables?
    Puritan PSM156
  • brianle
    brianle Posts: 572
    max $1000 new or used
  • mikeyb128
    mikeyb128 Posts: 2,885
    brianle wrote: »
    MIT clearance center will get you nice speaker cables and interconnects for up to 70% off. Every Tuesday they have new sales, I would be a little patient and shop there. I got magnum interconnects for a little under 300 bucks, and most recently shot gun s1 speaker cables for around 500. DO IT :)
    2 channel:
    Theater:
