$3K preamp giveaway
Hello, and welcome. I'm Andy Tebbe, president of Backert Labs. We hope this post is permitted, we couldn't find a place to ask if it was OK, so here goes...
Short version!
We're having a giveaway contest. If you come up with the best name for our new preamp, you win one.** Enter here.
Long version!
Last year we introduced our $7,500 single-ended linestage preamp, the Rhythm 1.1. This year, we are introducing a new model that has almost all of the sound of the Rhythm, at less than half the price. $2,995 to be exact.
And, we're giving one away.
The fact is, our new model doesn't have a name yet. So if you submit a name and we use it, you win one.** :smiley: (You can submit up to 3 names)
If you want to learn a bit about it first so that your name suggestions are even more awesome, check out our press release.
Once you have some ideas, enter them here.
If we don't use any of the submitted ideas, we will still give away a free preamp (by random drawing from all entries).
**If we choose a name that was submitted multiple times, the winner will be chosen at random from those entries.
No purchase necessary to enter, or to win. Any resulting taxes will be the winner's responsibility. Void where prohibited; otherwise, all U.S. residents 18 and over other than Rhode Island are eligible to enter.
Our new model:
Good luck!
The preamp specialists. http://BackertLabs.com
«13456
  • Joey_V
    Joey_V Posts: 8,600
    I'm game.
    1. Backert Tempo
    2. Backert Clarity
    3. Backert Harmony
  • Nightfall
    Nightfall Posts: 10,084
    edited September 2015
    Thanks, @nbrowser
    afterburnt wrote: »
    Village Idiot of Club Polk
  • A bit of info... since we said these things on another forum, we should say them here too...
    Sonics
    The intended sonic focus of the new $2,995 preamp that is the subject of the September Preamp Giveaway: live sound. So, rhythm. Dynamics. Excitement, when called for. Beauty.
    Sound quality that is extremely close to its big brother, the Rhythm 1.1, which caused NewRecordDay.com to announce: "You want this. Trust me - you want it bad."
    In Through the Out Door
    It has 3 RCA inputs, and 1 XLR input. 2 RCA outputs, and 1 XLR output. It is single-ended. It also has a home theater bypass, and a REC OUT for sending a full strength signal to a CD recorder or headphone amp.
    Tubes and Caps
    The interior is kept simple. One gain stage only, using the lowest-gain tube that is commonly found, the 12au7, so that negative feedback is not required, and so users can "tube roll" with ease. The handy see-through tube access door helps with this -- no tools are necessary to access the tubes. The unit's overall gain is 9dB. Capacitors are minimized, for example, the entire power supply AND regulator together have less than 3uF total. Most engineers will tell you this is impossible. The filament supply uses additional uF.
    I Have The Powerrrrrr.....
    Pure Class A design. Yet, uses less electricity than a 25W light bulb. It has our patented GreenForceTM power supply, so the music signal-carrying power supply capacitors are high quality polypropylene, rather than typical electrolytic caps. Toroidal transformer. HEXFRED diodes (only the best). Uses an IEC inlet instead of a captive power cord, allowing power cord experimentation. Easily convertible to 230V.
    The Hits Keep Coming
    Designed and built in USA. Remote volume control. Mute switch. Faceplate machined from solid aluminum. RCA jacks sturdy and generously spaced so no interconnect will ever be a problem. No screws or fasteners visible to the user, except for our handy tube access door. No ugly ventilation slats visible, although we do get ventilation done. The tubes are so minimally stressed that the tube access door which is directly above them barely gets warm.
    The new Backert Labs ___________________. What would you call it?
    tonyb Posts: 33,072
    Thanks for all the info. Already sent some suggestions. Love the clean and simple look.
  • Thanks for the kind words. Just a reminder that there is less than 1 week left to enter the September Preamp Giveaway. Good luck!
  • trj
    trj Posts: 320
    It looks nice. Submitted.
    Sony BDP-S6500 | Raspberry Pi 2 | XBOX One S | Wii --> Yamaha RX-V667 --> Adcom 5006 bridged to 175 watts for front LCR -- >Front: Polk Audio RTi8s | Center: CSi5 | Side Surrounds: RTi4s | Rear surrounds: FXiA4s | Cheap 12" sub woofer|Samsung UN60KU6300
  • polrbehr
    polrbehr Posts: 2,842
    Done.
  • Hello gents... Tomorrow is the last day to enter... 11:59 Eastern Time on Sep. 30 is the deadline! Good luck to all!
  • agfrost
    agfrost Posts: 2,469
    You're all fighting for 2nd place--I submitted *two* winning entries.
    Jay
  • boston1450
    boston1450 Posts: 7,758
    ^^^ thats ok. I only needed one :smile:
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
    tonyb Posts: 33,072
    You guys are all 2nd place, I've got the winner. ;)
    I did happen to notice in the specs only 9db of gain, pretty low, so take that into consideration. Kinda curious though as this seems to be the first "Green" type of audio gear to come down the pike.
  • I threw my names into the hat. Maybe they like em, maybe they hate em... we will see....
    Either way I've got a shot at the pre-amp :smile:
  • erniejade
    erniejade Posts: 6,321
    I say call it pizza or Penthouse. Most guys would at least look at the product if not consider it! >:)
    gudnoyez Posts: 8,161
    Well hopefully I win this with my entries, the power ball would also be nice, anyways don't get your hopes up none compare to my three names. I best start making some room for my Backer Labs - - - - - - - - - preamp fill in the blanks fellas.
    tonyb Posts: 33,072
    gudnoyez wrote: »
    The only Lab your gonna see is one with 4 legs buddy boy.... :)
  • We are literally laughing out loud reading you guys and your back-and-forth! Polk forums wins the best place we have ever advertised this giveaway.
  • tonyb wrote: »
    Very observant! **But** you can ask for more gain, and it shall be yours! Anything up to 18dB very easily, even up to 24dB if you want (although you probably don't want THAT much).
    Good luck!
    Toolfan66 Posts: 18,062
    Ha, I have been quiet, and I just received an email stating that I won!!
    Now you guys can bow, and kiss my big toe!! LOL!!
  • Toolfan66 wrote: »
    And considering that there are still 2 hours left before the contest ends, you know his entry had to be THAT good :)
  • Nightfall
    Toolfan66 wrote: »
    I can't tell if you're serious or not? Either a congrats to you or a fooled ya on me!
    afterburnt wrote: »
  • teekay0007
    teekay0007 Posts: 2,289
    gudnoyez wrote: »
    To the back of the line with your a$$!! Had you submitted a winning entry, they would have disqualified you for spelling the company's name wrong! :p
  • Almost missed this opportunity, submitted.
  • Nightfall wrote: »
    He was definitely not serious, lol
  • Nightfall
    If I would have just scrolled up a little and read the older posts about tonight being the deadline...
    Anyhow, it's close enough to the deadline that I feel I can share with you guys my winning entry.
    Backert Cadence
    Say it out loud. It not only has a nice ring to it, it's the sound of a winner.
    afterburnt wrote: »
    [/quote]
    I Blame spell check on that. I can assure you Terry there was no mistake or a spelling error on the official entry. Your welcome to come on down and be my honorary guest when I hook up my Bakertlabs - - - - - - - preamp.
    Nightfall wrote: »
    Backert Cadence
    Hey how dare you steal my third entry :| if it's a tie we will have to flip a coin, it does have a good ring to it , Cadence!
    tonyb Posts: 33,072
    If one of us wins or not, just want to thank you guys over at Backert labs for the opportunity. Keep us posted on new stuff, reviews, deals and what not.
  • TonyB, yes we shall. The first reviewer has now heard our new baby, and we will post his initial thoughts very soon. Thanks to all who entered!
    F1nut Posts: 51,772
    Ah, someone who appreciates how we roll here. It helps to make up for those thin skinned, know nothings. Yeah, we know who you are.
  • I submitted 3 names, but it was around 11:35pm central time. Does that mean my suggestions won't be considered?
