SDA 2A Re-veneering
lbcgav
Has anyone here put real wood veneer on their SDA's? I just got done re-capping the crossovers (still need to seal the cabs) and I'm thinking of re-veneering the cabinets. I know I'd be in for a lot of work. I've done a lot of veneering in the past (monitor 5jr's, 7 sansui receivers), but nothing as large as these SDA 2s. The only thing going for these things is that they don't have the beveled edge the Monitor 5Jr's had.
If anyone has done this before, I'd love to hear about it.
Thanks in advance.
Thanks in advance.
Do a search for veneer, should come up with plenty of hits.
My most recent veneer job was a pair of Monitor 10s: http://www.polkaudio.com/forums/showthread.php?149215-Monitor-10-Rebuild-with-quot-TL-quot-ModHas anyone here put real wood veneer on their SDA's? I just got done re-capping the crossovers (still need to seal the cabs) and I'm thinking of re-veneering the cabinets. I know I'd be in for a lot of work. I've done a lot of veneering in the past (monitor 5jr's, 7 sansui receivers), but nothing as large as these SDA 2s. The only thing going for these things is that they don't have the beveled edge the Monitor 5Jr's had.
Thanks in advance.
A little smaller than the 2As, but the process is the same. I used PSA backed, quarter sawn walnut. I also bought a roll of matching PSA backed edge banding for the front bevel. Went on like butter.Home Theater/2 Channel:
dhsspeakerservice.com/ -
Look at bottom of this page .... Similar threads also & get ideas that may help. Also awesome projectsRandy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
Great idea on the edge banding. Thanks for the replies.westmassguy wrote: »My most recent veneer job was a pair of Monitor 10s: http://www.polkaudio.com/forums/showthread.php?149215-Monitor-10-Rebuild-with-quot-TL-quot-Mod
A little smaller than the 2As, but the process is the same. I used PSA backed, quarter sawn walnut. I also bought a roll of matching PSA backed edge banding for the front bevel. Went on like butter. -
Here's my veneer job on my 4.1TL's:
http://www.polkaudio.com/forums/showthread.php?137026-My-new-4.1TL-s-are-complete!Good music, a good source, and good power can make SDA's sing. Tubes make them dance. -
You did a beautiful job on thoseHere's my veneer job on my 4.1TL's:
http://www.polkaudio.com/forums/showthread.php?137026-My-new-4.1TL-s-are-complete!Home Theater/2 Channel:
westmassguy wrote: »You did a beautiful job on those
Cheers! Credit goes to my brother-in-law for the veneer job, though.Good music, a good source, and good power can make SDA's sing. Tubes make them dance. -
Are you still around? If you are please follow up.
Thanks in advance.[/QUOTE]Has anyone here put real wood veneer on their SDA's? I just got done re-capping the crossovers (still need to seal the cabs) and I'm thinking of re-veneering the cabinets. I know I'd be in for a lot of work. I've done a lot of veneering in the past (monitor 5jr's, 7 sansui receivers), but nothing as large as these SDA 2s. The only thing going for these things is that they don't have the beveled edge the Monitor 5Jr's had.
If anyone has done this before, I'd love to hear about it. -
Sorry for not following up. Been too busy to do any work on these. Hopefully after the holidays I can get some veneer and get back to work. I'll post some progress pictures when I start. I doubt it will be for a while though.Are you still around? If you are please follow up.
Thanks in advance.Has anyone here put real wood veneer on their SDA's? I just got done re-capping the crossovers (still need to seal the cabs) and I'm thinking of re-veneering the cabinets. I know I'd be in for a lot of work. I've done a lot of veneering in the past (monitor 5jr's, 7 sansui receivers), but nothing as large as these SDA 2s. The only thing going for these things is that they don't have the beveled edge the Monitor 5Jr's had.
Great, looking forward to seeing your progress.Sorry for not following up. Been too busy to do any work on these. Hopefully after the holidays I can get some veneer and get back to work. I'll post some progress pictures when I start. I doubt it will be for a while though.Home Theater/2 Channel:
Well it's been nearly two years and I realize I never updated with details. Here are some recent pics of the SDA 2A's.
I just got a beautiful pair of SDA SRS 2's. I'll start a new thread for those.
I redid the crossovers on the 2A's and did the usual upgrades (RDO-194's, hurricane nuts, dynamite, epoxying the magnets, etc.).
Very NiceRandy-Maine
by David WMG
Beautiful!Home Theater/2 Channel:
Very nice!
Looks great!Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
lbcgav- Those SDA's look like nice pieces of furniture, just beatiful!
I have a pair of SDA-2B studios in walnut laminate that I was thinking of veneering. I'm new at this and had a few questions:
Did you apply the veneer over the old laminate?
Did you use PSA backed veneer?
For the edging, did you use iron on edgebanding or cut it out of the larger veneer sheet?
Did you remove the bottom trim piece before veneering- if so, how?
Thanks, DonSpeakers: Polk SDA-SRS xovers rebuilt by David, RDO194's, Dynamat, BH5, glued magnets, new cloth, custom aluminum terminal plates with Cardas posts and Speakon interconnect
Speaker Cables, Jumpers & Interconnect: DIY Douglas Connection
Power Amp: Sunfire Architect's Choice Series II
Preamp: Adcom GFP-750
SACD/CD: Oppo BDP-95
Tuner: Sansui TU-717
TT: Technics SL-MA1
Phono Pre: Emotiva XPS-1
Music Server: Mac Mini w/JRiver - iPad w/JRemote
DAC: Eastern Electric MiniMax Plus
Other Polks: SDA: 1A, 1C, 2B, CRS+ / Monitor: 10A, 5jr, 4 / RT5 -
In a related question can you put some clear poly on a set of vinyl rapped M7s ?
I think these are faux rosewood and need some shine to them. Would clear poly pull up the vinyl or is there some other product to use. Pix are a little deceiving and don't look that good in my real world setting. Corners on 1 are somewhat chewed upon also.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
Did you apply the veneer over the old laminate? No. Stripped the vinyl first with a heat gun.
Did you use PSA backed veneer? No, I used contact cement on paper backed veneer.
For the edging, did you use iron on edgebanding or cut it out of the larger veneer sheet? I used iron-on edge banding.
Did you remove the bottom trim piece before veneering- if so, how? Yes. I was able to separate it partially just enough to get a hack saw blake between the trim and the cabinet. This was enough to cut the screws that held it on. Afterwards, I scored the back of the trim piece and the cabinet and used Gorilla Glue to secure it back on. This is after veneering of course. To veneer the trim piece, I trimmed the veneer to roughly the same size as the trim piece and wetted the edges and clamped it onto the trim piece. When it dries, it keeps the shape of the curve and can then be attached with contact cement without curling off the curved portion.
Thanks, Don -
leftwinger57 wrote: »In a related question can you put some clear poly on a set of vinyl rapped M7s ?
I don't think you can put poly over vinyl. I'm not sure there's anything you can put on them that would restore the shine permanently. You could put some Howard's feed'n'wax on it, but that will leave a film on top that will collect dust. -
lbcgav, thanks so much for the detailsSpeakers: Polk SDA-SRS xovers rebuilt by David, RDO194's, Dynamat, BH5, glued magnets, new cloth, custom aluminum terminal plates with Cardas posts and Speakon interconnect
TT: Technics SL-MA1
