SDA 2A Re-veneering
lbcgav
lbcgav Posts: 23
edited December 2013 in Vintage Speakers
Has anyone here put real wood veneer on their SDA's? I just got done re-capping the crossovers (still need to seal the cabs) and I'm thinking of re-veneering the cabinets. I know I'd be in for a lot of work. I've done a lot of veneering in the past (monitor 5jr's, 7 sansui receivers), but nothing as large as these SDA 2s. The only thing going for these things is that they don't have the beveled edge the Monitor 5Jr's had.
If anyone has done this before, I'd love to hear about it.
Thanks in advance.
Post edited by lbcgav on
    F1nut Posts: 52,064
    Do a search for veneer, should come up with plenty of hits.
  • westmassguy
    westmassguy Posts: 6,850
    lbcgav wrote: »
    Thanks in advance.
    My most recent veneer job was a pair of Monitor 10s: http://www.polkaudio.com/forums/showthread.php?149215-Monitor-10-Rebuild-with-quot-TL-quot-Mod
    A little smaller than the 2As, but the process is the same. I used PSA backed, quarter sawn walnut. I also bought a roll of matching PSA backed edge banding for the front bevel. Went on like butter.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • boston1450
    boston1450 Posts: 7,758
    Look at bottom of this page .... Similar threads also & get ideas that may help. Also awesome projects
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • lbcgav
    lbcgav Posts: 23
    Great idea on the edge banding. Thanks for the replies.
  • nspindel
    nspindel Posts: 5,343
  • westmassguy
    nspindel wrote: »
    You did a beautiful job on those
  • nspindel
    Cheers! Credit goes to my brother-in-law for the veneer job, though.
  • NJPOLKER
    NJPOLKER Posts: 3,475
    Are you still around? If you are please follow up.
    Thanks in advance.[/QUOTE]
    lbcgav wrote: »
  • lbcgav
    lbcgav Posts: 23
    Sorry for not following up. Been too busy to do any work on these. Hopefully after the holidays I can get some veneer and get back to work. I'll post some progress pictures when I start. I doubt it will be for a while though.
    NJPOLKER wrote: »
    Thanks in advance.
    lbcgav wrote: »
  • westmassguy
    lbcgav wrote: »
    Great, looking forward to seeing your progress.
  • lbcgav
    lbcgav Posts: 23
    edited August 2015
    Well it's been nearly two years and I realize I never updated with details. Here are some recent pics of the SDA 2A's.
    I just got a beautiful pair of SDA SRS 2's. I'll start a new thread for those.
    I redid the crossovers on the 2A's and did the usual upgrades (RDO-194's, hurricane nuts, dynamite, epoxying the magnets, etc.).
  • boston1450
    Very Nice
    Randy-Maine
    by David WMG
  • westmassguy
    Beautiful!
    F1nut Posts: 52,064
    Very nice!
  • nspindel
    Looks great!
  • stogie
    stogie Posts: 230
    lbcgav- Those SDA's look like nice pieces of furniture, just beatiful!
    I have a pair of SDA-2B studios in walnut laminate that I was thinking of veneering. I'm new at this and had a few questions:
    Did you apply the veneer over the old laminate?
    Did you use PSA backed veneer?
    For the edging, did you use iron on edgebanding or cut it out of the larger veneer sheet?
    Did you remove the bottom trim piece before veneering- if so, how?
    Thanks, Don
    Speakers: Polk SDA-SRS xovers rebuilt by David, RDO194's, Dynamat, BH5, glued magnets, new cloth, custom aluminum terminal plates with Cardas posts and Speakon interconnect
    Speaker Cables, Jumpers & Interconnect: DIY Douglas Connection
    Power Amp: Sunfire Architect's Choice Series II
    Preamp: Adcom GFP-750
    SACD/CD: Oppo BDP-95
    Tuner: Sansui TU-717
    TT: Technics SL-MA1
    Phono Pre: Emotiva XPS-1
    Music Server: Mac Mini w/JRiver - iPad w/JRemote
    DAC: Eastern Electric MiniMax Plus
    Other Polks: SDA: 1A, 1C, 2B, CRS+ / Monitor: 10A, 5jr, 4 / RT5
  • In a related question can you put some clear poly on a set of vinyl rapped M7s ? luin78k4eo09.jpg
    I think these are faux rosewood and need some shine to them. Would clear poly pull up the vinyl or is there some other product to use. Pix are a little deceiving and don't look that good in my real world setting. Corners on 1 are somewhat chewed upon also.
  • stogie wrote: »
    Did you apply the veneer over the old laminate? No. Stripped the vinyl first with a heat gun.
    Did you use PSA backed veneer? No, I used contact cement on paper backed veneer.
    For the edging, did you use iron on edgebanding or cut it out of the larger veneer sheet? I used iron-on edge banding.
    Did you remove the bottom trim piece before veneering- if so, how? Yes. I was able to separate it partially just enough to get a hack saw blake between the trim and the cabinet. This was enough to cut the screws that held it on. Afterwards, I scored the back of the trim piece and the cabinet and used Gorilla Glue to secure it back on. This is after veneering of course. To veneer the trim piece, I trimmed the veneer to roughly the same size as the trim piece and wetted the edges and clamped it onto the trim piece. When it dries, it keeps the shape of the curve and can then be attached with contact cement without curling off the curved portion.
    Thanks, Don
    I don't think you can put poly over vinyl. I'm not sure there's anything you can put on them that would restore the shine permanently. You could put some Howard's feed'n'wax on it, but that will leave a film on top that will collect dust.
  • stogie
    stogie Posts: 230
    lbcgav, thanks so much for the details
    TT: Technics SL-MA1
