IEC Inlet Questions
13»
    F1nut Posts: 52,283
    After much research here and there I decided to buy the Furutech Audio Grade FI-06 gold plated pure copper IEC inlets. The FI-09's 50mm screw hole spacing is just too wide for my applications.
    F1nut Posts: 52,283
    Negative
  • Hermitism
    Hermitism Posts: 4,345
    Negative
    You ordered it over the phone and talked to Jeff, didn't you?
    F1nut Posts: 52,283
    Negative
    Hermitism wrote: »
    Negative
    He's JESSE! They sensed a disturbance in the force and called him....
    These are NOT the IECs your looking for....
    I'm slap happy... Sleepy time.
  • codyc1ark
    codyc1ark Posts: 2,539
    ^ Nerd alert ^
  • helipilotdoug
    The FI-06 is a great performer and really good bang for the buck. You'll be pleased Jesse. Call me when you are looking for something like this. You might be glad you did ;)
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
    F1nut Posts: 52,283
    Will do, Doug.
    F1nut Posts: 52,283
    Super fast delivery from Canada. Shipped on the 3rd, arrived on the 8th. I just finished installing both of them on 2 different pieces. Impressive build quality with some real heft and a positive lock on the power cord........me like. B)
    I'll report on the sound when I get some listening time on them.
    Oh the horror Jess, how can build quality and metallurgy have any effect on the sound. :p
    F1nut Posts: 52,283
    Ok, I've got about 50 hours on the new IEC in the office rig, so time for a few comments. The UPC-200 in the office was retro-fitted with PS Audio Power Port Premier (Gold) outlets many months ago, which netted an improvement, so upgrading the IEC was logical. Installing the Furutech Audio Grade FI-06 (Gold) was about as straight forward as it gets.
    Upon first listen I noticed the sound had become somewhat dull....hmmm. I set the SACD/CD player on repeat and let it play for the last 2 days most of which I haven't been around due to work. So, tonight I got a chance to do some critical listening. The sound is no longer dull, in fact it sounds better than ever. There was a touch of glare previously that is now gone, tactile bass has increased and there is a slight increase in clarity. Conclusion, the noise floor has dropped and F1 is a happy camper. I also installed brand new Power Port Premier outlets and the Furutech FI-06 IEC in the UPC-200 connected to my main rig, but I haven't had any time to listen to it since doing so, but I would expect similar results.
    I will be replacing the stock IEC's on the office and main rig gear in the very near future.
    The pic with the light gray outlets is the original main rig UPC-200, the other two are different views after the retro-fit. It's true, all that glitters is gold. B)
  • zumbini
    zumbini Posts: 654
    edited September 2015
    @F1nut : Glad you are happy with your purchases but your results (and flowery prose) remind me of studies I participated in in the mid-70's. Can you spell "expectation bias"?
    Main System
    Carver Gear: C-11 (refit & modded, w/balanced outs), M-500 (refit), M-500t(x2) (refit), M-1.0t (refit & upgraded), SD/A 490t, TX-11b
    Other Electronics: Behringer CX3400, Behringer FBQ3102, Furman PS-8R-II, Nikko NPS-1, Teac C-3RX, Technics SL-D303
    Speakers: Legacy Audio Custom Super Satellites (new drivers & bi-ampable XOs), Legacy Audio Custom Subwoofers
    Carver Office System: C-2 (refit & modded, w/balanced outs), DTL-50, M-200t, TX-2, Musical Fidelity X-10D, Design Acoustics DA-30 (DA-20LF sub w/4 DA-10 satellites)
    Workshop System: Carver MXR-130 receiver, Carver DTL-50 CDP, Design Acoustics DA-30 (DA-20LF sub w/2 DA-10 satellites)
    Son's System: Carver CT-7, Carver DTL-200MK2, Carver M-1.5t (refit), Hitachi PS-38 (TT), Polk SDA-SRS 1.2tl, Klipsch KG2.5, PSB Century Subsonic 2i powered sub
    Not In Use or Need Repair: Denon DCM-35 (CDC), Teac X10R (RTR), Technics SL-1200MK1 (TT), Yamaha CDX-820 (CDP)
    F1nut Posts: 52,283
    I've had very nice looking, high dollar stuff that my ears didn't like, so expectation bias plays absolutely no role.
    Speaking of spelling, would you like to buy a vowel?
