My Drywalling Nightmare...
  • Moose68Bash
    Moose68Bash Posts: 3,843
    That's pretty amazing to a guy like me!
    I have trouble patching the 4"x4" holes my daughters have on occasion made in the walls of their rooms!
    Looks like a major accomplishment to me! :)
  • WagnerRC
    WagnerRC Posts: 2,204
    nice job! my least favorite job
  • afterburnt
    afterburnt Posts: 7,892
    Moose are your daughters in the roller derby or something?
  • kevhed72
    kevhed72 Posts: 5,146
    one of the rooms you see through the doorway is my audio room....so close....
  • mrbiron
    mrbiron Posts: 5,721
    Who doesn't love drywall!!!!
    Looks good....now hurry up. B)
  • Looking good! That's a whole lot of dirty work though, enjoy.
  • strider
    strider Posts: 2,568
    WagnerRC wrote: »
    +1 on both points.
    Wristwatch--->Crisco
  • rooftop59
    rooftop59 Posts: 8,121
    Drywall is one home project I have yet to tackle...with four kids I'm sure it will happen.
    Looks like ur making good progress! Good luck with the rest!
    Game Room 5.1.4:
    Bedroom 2.1
  • Moose68Bash
    edited August 2015
    afterburnt wrote: »
    @afterburnt,
    LOL
    No, not rollerbladers.
    One time the older one returned from the beach having remained in the relatively cold water too long, suffered hypothermia, fell into a chair, which fell into the wall and made a hole that I had to patch.
    Then, she wanted to remove a non-working intercom pad in her condo, which left a hole of about 4"x4" to patch.
    The younger daughter had a guest in her apartment who banged a suitcase into the wall and made a "dimple" that required a patch of about 4"x4."
    The best one, however, I cannot attribute to either daughter. Unbeknownst to my wife and me, a nest of wasps set up housekeeping in the attic space above our guest room.
    Eventually I saw a stain on the ceiling. When I gently pocked it, the wall board disintegrated to my touch, and the wasps poured out through the hole. That was an event to be remembered! After a visit from the exterminator and clean up, I had a 12"x12" hole to patch.
    Post edited by Moose68Bash on
  • afterburnt
    Now that's a drywall nightmare!
  • MrBuhl
    MrBuhl Posts: 2,419
    As a former drywaller (summers in college) we would definitely have called that "lots of funky angles" - which was not a compliment for the job to be done - nice work! It pays to do it right to start!
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • scottyboy76
    scottyboy76 Posts: 2,905
    Kev I gotta admit, with no more experience than you described, that is magnificent work.
    One thing I know is if you screw up drywall finishing and it drys, you have a hell of a mess and a lot of work to make it right.
    You should be rightfully proud.
    humpty dumpty was pushed
    tonyb Posts: 33,072
    Good job there Kev, frickin' nightmare with all those angles though. Your kids putting holes in the walls ? Anger management issues ? lol
  • gdb
    gdb Posts: 6,012
    Good looking work ! I don't mind the tape-block-skim part too much, it's the sanding that really bugs me ! You know about the light bulb trick, right ? ;)
  • kevhed72
    All too well. I am a bit of a detail freak to begin with. Last night I went on a major sanding tear in the audio room. Sanding sucks. All my taping was the adhesive mesh type, which you get used to. I dont have the patience to learn the paper tape.
    Fighting the urge to say F it and just roll on a texture....but ......must.....resist.....
    tonyb Posts: 33,072
    Your a better man than me Kev. My patience level is like zero for sanding drywall.
    I'm the type who would make a mistake, and buy a bigger screen TV to hide it.
  • steveinaz
    steveinaz Posts: 19,545
    You're a brave soul, nice job. I need to remove my panty liner and get the guts to try this one day.
  • kevhed72
    I dont encourage it unless:
    a. you do it for a living
    b. you have severe ocd and control issues, as I do.
    c. you have no life so you can spend all your free time working on, which somewhat applies to me
  • gdb
    gdb Posts: 6,012
    A little angular nightmare of my own in our under-stairs powder room. Need to do a seam fix on the wallpaper now. :)
  • mrbiron
    One does not do "seam fixes" on wallpaper. One rips out wallpaper....
    Is that gold trim?!?!?! :p
    tonyb Posts: 33,072
    edited August 2015
    mrbiron wrote: »
    Yep, rip that puppy off, wet the sh$t out of it first. Let it all dry and start sanding. Wallpaper was sent to us by the devil himself.
    After you rip the paper off, re wet it with a spray bottle and use a scraper to get the glue off. You can use regular water but they make better stuff to use you can get at any Home depot.
  • ken brydson
    ken brydson Posts: 9,002
    tonyb wrote: »
    mrbiron wrote: »
    Actually, 50/50 mix of water and vinegar works great.
  • gdb
    gdb Posts: 6,012
    Yeah. No. The time, effort and money that went into that wall covering doesn't dictate it's being stripped any time in the near future. Thanks, though. LOL
  • kevhed72
    I took wallpaper off the kitchen years ago for my parents....complete PITA.
    tonyb Posts: 33,072
    gdb wrote: »
    You can try some glue and a seam roller, but most likely won't look too keen. Wall paper has a shelf life, most don't realize, and when it's done, it's done. Putting it on is a pita and so is taking it off.
    I had one room in my house I removed the wall paper on, a good sized bedroom. Only, found out the hard way the previous owner had just wall papered over the previous paper......3 times. Talk about a pita.
    Good old paint works best imho, plus there's so much you can do with paint too.
  • gdb
    gdb Posts: 6,012
    Thanks, I think I'm in pretty good shape with my knowledge base of wall coverings. Seam repairs are no big thing. (if done properly)
  • Moose68Bash
    I bought a house with so-called "strippable" wallpaper once in my life. The wallpaper, in my wife's vernacular, was appropriate for a dentist's office, or as my secretary once described fabric for drapes, "dead birds."
    I managed to live with it for a couple of months, but came home from work one night and just started pulling it off the walls -- living room, dining room, entry hall, study.
    The stripping was a piece of cake. What I didn't realize was that the glue does not come off with the wallpaper.
    Oh my God, what a mess!
    After much spraying of water with a hand-pump sprayer and scraping with a taping knife, I finally got the glue off in about a month.
    That is one thing I shall never -- ever -- do again.
    I'm convinced that wallpaper was created as a punishment for something. I have no idea what for, but it must be a mortal sin of some sort!
  • gdb
    gdb Posts: 6,012
    LOL! Actually..... some people resort to using a special, 1/4" thick drywall and special screws to laminate a new wall surface onto old, papered or just plain rough walls. "Clean slate" so to speak. ;)
  • Moose68Bash
    edited August 2015
    gdb wrote: »
    Had I known about that, or if it had been available at the time, I likely would have taken that route.
    But, c'est la vie! I did what was necessary at the time.
    By the way, the ceilings were also a textured plaster of sorts, which my wife disliked so much that she spent an incredible amount of time rubbing the texture out with a wet sponge.
    Why did we buy that house? I don't know. It was on a nice little lake, and it seemed like a good idea at the time.
  • Stew
    Stew Posts: 645
    We rented a wallpaper steamer years ago to remove wallpaper. Heated water tank, hose and wand. Don't know if they're still available but worked like a charm.
    SDA 2B-TL (Sonicap/Solen/Mills, Erse Super Q, Rings, Spikes, No-Rez)
    1000VA Dreadnought
    Dared SL-2000a (Siemens & Halske TM 12AT7WA's, Brimar 5Z4G)
    Jolida JD-100a (Sylvania BP TM Gold Brand 5751's), NAD C275BEE, Blue Jeans
    RTiA3, Onkyo TX-SR605
