My Drywalling Nightmare...
  • Moose68Bash
    Moose68Bash Posts: 3,843
    That's pretty amazing to a guy like me!
    I have trouble patching the 4"x4" holes my daughters have on occasion made in the walls of their rooms!
    Looks like a major accomplishment to me! :)
  • WagnerRC
    WagnerRC Posts: 2,209
    nice job! my least favorite job
  • afterburnt
    afterburnt Posts: 7,892
    Moose are your daughters in the roller derby or something?
  • kevhed72
    kevhed72 Posts: 5,153
    one of the rooms you see through the doorway is my audio room....so close....
  • mrbiron
    mrbiron Posts: 5,721
    Who doesn't love drywall!!!!
    Looks good....now hurry up. B)
  • Looking good! That's a whole lot of dirty work though, enjoy.
  • strider
    strider Posts: 2,568
    WagnerRC wrote: »
    +1 on both points.
    Wristwatch--->Crisco
  • rooftop59
    rooftop59 Posts: 8,120
    Drywall is one home project I have yet to tackle...with four kids I'm sure it will happen.
    Looks like ur making good progress! Good luck with the rest!
    Game Room 5.1.4:
    Bedroom 2.1
  • Moose68Bash
    edited August 2015
    afterburnt wrote: »
    @afterburnt,
    LOL
    No, not rollerbladers.
    One time the older one returned from the beach having remained in the relatively cold water too long, suffered hypothermia, fell into a chair, which fell into the wall and made a hole that I had to patch.
    Then, she wanted to remove a non-working intercom pad in her condo, which left a hole of about 4"x4" to patch.
    The younger daughter had a guest in her apartment who banged a suitcase into the wall and made a "dimple" that required a patch of about 4"x4."
    The best one, however, I cannot attribute to either daughter. Unbeknownst to my wife and me, a nest of wasps set up housekeeping in the attic space above our guest room.
    Eventually I saw a stain on the ceiling. When I gently pocked it, the wall board disintegrated to my touch, and the wasps poured out through the hole. That was an event to be remembered! After a visit from the exterminator and clean up, I had a 12"x12" hole to patch.
    Post edited by Moose68Bash on
  • afterburnt
    Now that's a drywall nightmare!
  • MrBuhl
    MrBuhl Posts: 2,419
    As a former drywaller (summers in college) we would definitely have called that "lots of funky angles" - which was not a compliment for the job to be done - nice work! It pays to do it right to start!
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • scottyboy76
    scottyboy76 Posts: 2,905
    Kev I gotta admit, with no more experience than you described, that is magnificent work.
    One thing I know is if you screw up drywall finishing and it drys, you have a hell of a mess and a lot of work to make it right.
    You should be rightfully proud.
    humpty dumpty was pushed
    Good job there Kev, frickin' nightmare with all those angles though. Your kids putting holes in the walls ? Anger management issues ? lol
  • gdb
    gdb Posts: 6,012
    Good looking work ! I don't mind the tape-block-skim part too much, it's the sanding that really bugs me ! You know about the light bulb trick, right ? ;)
  • kevhed72
    All too well. I am a bit of a detail freak to begin with. Last night I went on a major sanding tear in the audio room. Sanding sucks. All my taping was the adhesive mesh type, which you get used to. I dont have the patience to learn the paper tape.
    Fighting the urge to say F it and just roll on a texture....but ......must.....resist.....
    Your a better man than me Kev. My patience level is like zero for sanding drywall.
    I'm the type who would make a mistake, and buy a bigger screen TV to hide it.
  • steveinaz
    steveinaz Posts: 19,545
    You're a brave soul, nice job. I need to remove my panty liner and get the guts to try this one day.
  • kevhed72
    I dont encourage it unless:
    a. you do it for a living
    b. you have severe ocd and control issues, as I do.
    c. you have no life so you can spend all your free time working on, which somewhat applies to me
  • gdb
    gdb Posts: 6,012
    A little angular nightmare of my own in our under-stairs powder room. Need to do a seam fix on the wallpaper now. :)
  • mrbiron
    One does not do "seam fixes" on wallpaper. One rips out wallpaper....
    Is that gold trim?!?!?! :p
    edited August 2015
    mrbiron wrote: »
    Yep, rip that puppy off, wet the sh$t out of it first. Let it all dry and start sanding. Wallpaper was sent to us by the devil himself.
    After you rip the paper off, re wet it with a spray bottle and use a scraper to get the glue off. You can use regular water but they make better stuff to use you can get at any Home depot.
  • ken brydson
    ken brydson Posts: 9,013
    tonyb wrote: »
    mrbiron wrote: »
    Actually, 50/50 mix of water and vinegar works great.
  • gdb
    gdb Posts: 6,012
    Yeah. No. The time, effort and money that went into that wall covering doesn't dictate it's being stripped any time in the near future. Thanks, though. LOL
  • kevhed72
    I took wallpaper off the kitchen years ago for my parents....complete PITA.
    gdb wrote: »
    You can try some glue and a seam roller, but most likely won't look too keen. Wall paper has a shelf life, most don't realize, and when it's done, it's done. Putting it on is a pita and so is taking it off.
    I had one room in my house I removed the wall paper on, a good sized bedroom. Only, found out the hard way the previous owner had just wall papered over the previous paper......3 times. Talk about a pita.
    Good old paint works best imho, plus there's so much you can do with paint too.
  • gdb
    gdb Posts: 6,012
    Thanks, I think I'm in pretty good shape with my knowledge base of wall coverings. Seam repairs are no big thing. (if done properly)
  • Moose68Bash
    I bought a house with so-called "strippable" wallpaper once in my life. The wallpaper, in my wife's vernacular, was appropriate for a dentist's office, or as my secretary once described fabric for drapes, "dead birds."
    I managed to live with it for a couple of months, but came home from work one night and just started pulling it off the walls -- living room, dining room, entry hall, study.
    The stripping was a piece of cake. What I didn't realize was that the glue does not come off with the wallpaper.
    Oh my God, what a mess!
    After much spraying of water with a hand-pump sprayer and scraping with a taping knife, I finally got the glue off in about a month.
    That is one thing I shall never -- ever -- do again.
    I'm convinced that wallpaper was created as a punishment for something. I have no idea what for, but it must be a mortal sin of some sort!
  • gdb
    gdb Posts: 6,012
    LOL! Actually..... some people resort to using a special, 1/4" thick drywall and special screws to laminate a new wall surface onto old, papered or just plain rough walls. "Clean slate" so to speak. ;)
  • Moose68Bash
    edited August 2015
    gdb wrote: »
    Had I known about that, or if it had been available at the time, I likely would have taken that route.
    But, c'est la vie! I did what was necessary at the time.
    By the way, the ceilings were also a textured plaster of sorts, which my wife disliked so much that she spent an incredible amount of time rubbing the texture out with a wet sponge.
    Why did we buy that house? I don't know. It was on a nice little lake, and it seemed like a good idea at the time.
  • Stew
    Stew Posts: 645
    We rented a wallpaper steamer years ago to remove wallpaper. Heated water tank, hose and wand. Don't know if they're still available but worked like a charm.
    SDA 2B-TL (Sonicap/Solen/Mills, Erse Super Q, Rings, Spikes, No-Rez)
    1000VA Dreadnought
    Dared SL-2000a (Siemens & Halske TM 12AT7WA's, Brimar 5Z4G)
    Jolida JD-100a (Sylvania BP TM Gold Brand 5751's), NAD C275BEE, Blue Jeans
    RTiA3, Onkyo TX-SR605
