Bottlehead Crack
I'm going to need a blow torch to correct the base issue. Sad I overlooked that minor issue this entire time.
I gave it a quick hour of run time for now. I'll give it a workout tomorrow during "daddy's beer time".
I plug everything into the Peachtree. Its the core man...THE CORE!!!Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
Guess what I'm doing.......
Oh crap the base is backwards!!... Guess I'll have to start over.
LOL Bottlehead humor.....
Kewl beans! Sometimes inexpensive and even mid range price volume pots don't balance volume for both channels equally well at lower levels anyway. Like a balance control, one channel will become slightly louder to shift center image. Cure for that is go resistor ladder network, but that can some mild to wild pricing.
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
It took me a little over 7hours to de-solder everything to get the base issue corrected. My wife asked why I couldn't just spin the base?...*snicker* women are so silly......
I wish I could/would have painted the socket white as well. Its really bothering me.
Good move and hours well spent. You do realize the Crack only sounds good if it is soldered correctly inline with the logo. Sounds like AM radio if it's not done right.Aaron
Enabler Extraordinaire -
Looking good! Nice job!
Now remember all those caps need some burn in time, so time to get your ears on for at least a good 100 hours2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
Beautiful job. Congrats!b]Beach Audio[/b]: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
Town Porch: WiiM Pro Plus * Sunfire Sig II * Canare 4S11 * Magnepan 1.6 * Dectet -
That damn socket!!!! Arrrgg!!!!
Now I have to find time to use it. The competition will start in a couple months to see if I actually keep it
BH Crack vs PS Audio Sprout vs Peachtree DeccoWhere’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
Looks great!
No guts no glory...you can remove the socket cover easy enough and detail it. That's why I left mine au naturel, just for a little shiny stuff among the black panel.
I really dared the Bottlehead badge sound quality gods by placing mine flat on the top left corner of panel. I think it's a first, but I haven't seen pics of all BH builds.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Resurrection...
The drawing for the BAC. 10" x 12" with the original plate at the top.
Aaron
wait... is the volume control under the 12au7 tube? Think I like the new one then.2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
input on left, volume in middle, jack on right. Hope to figure out how to take out the 12AU7 and use a 6SN7 instead. Might move the on/off down the chassis about 1/2 way also.Aaron
Where is the fuel tank going to go?
Hurry up....Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
Sweet jebus, big enough?Where is the fuel tank going to go?
Hurry up....
He's gonna use a...
Way too small... Going nuclear (got some stuff from N. Korea!!)
Aaron
Always gotta go to extremes....lol
I'm gonna buy something for a change. Parks Audio SUT w/Blue CineMag trannies. Reasonably priced compared to some ($339 shipped). Wired 1:9 & 1:18 (instead of 1:18 & 1:36). Too much gain with the Eros and my 1:18 & 1:36 SUT, even on low with my Ref 3. I don't want to take my DIY SUT apart, just leave it at 1:18 & 1:36. That worked perfect with your less gain Reduction/Integration. I'm sure I'll have a use for it again someday...
Looks cool! Where's the plans for your fist one? The DIY?
Aaron
Here is my revised CineMag ground scheme. I got the extra enclosure from Carl pre-drilled with RCA holes. We did innie trannies. I built three, one for Carl, one for Larry, one for me. The 3440AH or blues can be wired for 1:9/1:18 or 1:18/1:36.
I used these DPDT On/On switches from Digikey, CKN1032-ND. Pricey (~$9 each), they were chosen for aesthetics, are sealed with gold plated contacts. Sealed and silver plated would also be good.
http://www.digikey.com/product-detail/en/7201P3YZBE/CKN1032-ND/5559Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Nice preamp.Jay
Does anyone have the non-explosive illudium Q-36 space modulator? I need one.
Aaron
Resurrection...
Where is this BAC!!!!????Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
Looks like I hit preview instead of post!
All parts are in ...I think. Transformer is painted, bell polished. I still have some mods to make on the top plate. New holes for the 8 pin sockets and I need to drop the transformer down a bit to get the choke in.
Aaron
Now that is a pretty site!!2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
This choke?
or this one?
Ya know....with friends like this....Aaron
So, you still use all of the basic wiring from the original schematic and drop those oil drums in place the "puny" caps?
What stepped attenuator is that?
Are you swapping out the cheapo binding posts for something more robust?
And where did you get those BLACK sockets!?!?! That is what i want for mine. I hate the white!!!! ROARRRRR!! AHHH!!!! VVVRRROOOOMMMM!!!Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
yep, most of the wiring will remain the same. the 12au7 is replaced with a 6sn7, but that's just a different pin-out at the socket.
Attenuator is from Goldpoint.
Binding posts are Vampire's.
The black sockets I only got to piss you off, I have no intention of actually using them.
Ok, just kidding. Parts Connexion has them.Aaron
Well, you did a good job at that. Now i'm angry that YOU didn't mention them a while ago when i was complaining about the white. You just want your BAC to look nicer than my simple crack. Selfish SOB!
Im not changing them now!Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
Don't be a hater - didn't know they existed until recently. But if I had I wouldn't have told you anyway!!Aaron
