PSW505 Power But No Audio
My PSW505 began popping intermittently. has now quite working completely. We have check all of the settings on the receiver.
  • [Deleted User]
    Hello,
    Welcome to Polk's forum. In order to determine if the subwoofer is the cause try this:
    a). turn the subwoofer's volume all the way down and remove the sub-cable from the back of the subwoofer.
    b). bring your CD or DVD player to the sub's location and connect the right and left line level outputs of the CD/DVD player to the corresponding right and left line level inputs on the sub.
    c). then begin playing a CD and slowly turn the volume up on the subwoofer. There should be plenty of bass at a low volume setting.
    Regards, Ken
  • [Deleted User]
    [Deleted User] Posts: 10,716
    Ken's suggestion is a good one. Apparently the LFE blows easily.
    The L/R is the way to keep the sub going or speaker in/outs.
  • timthompson
    Thanks for the info. I followed your instructions and have no audio. I also took it and hooked it to my son-in-laws system. Nothing. It's just over a year old. Purchased it in June last year. Any help Polk could give would be appreciated.
  • [Deleted User]
    Hello,
    You should be under the warranty coverage, give Polk CS a call at 1-800-377-7655 or send an email to polkcs@polkaudio.com. Have the date and place of purchase and the serial number when you contact them.
    They'll take care of you.
    Regards, Ken
  • timthompson
    Talked to Polk CS and it was great. Sending me a new amp. Great service.
  • [Deleted User]
    I'm glad you were able to get some good results, very cool.
