this followed me home today
Rotel rp 1100Q it is nothing special i think but it's pretty and it was scarry cheep.nm9r0q133y9o.jpg
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
  • mantis
    mantis Posts: 17,365
    It looks in great shape, have fun with that. You got a Rotel, nice!
    Dan
  • hochpt21
    hochpt21 Posts: 5,423
    Very nice looking. I didn't know Rotel ever made TT's.
    Funny how those things end up just following you home :)
  • soundfreak1
    soundfreak1 Posts: 3,414
    Its is very clean. Those picts are before i touched it.dont think its gonna stay but damn its pretty. LOL i just love the vintage TT wood box look! If it could do as well as the sl1700 (im sure it cant) I'd love it in my rack. Gonna play with it make sure all is well with it . I just couldn't walk away from it.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • soundfreak1
    hochpt21 wrote: »
    It wispered to me, and i was done. The stanton 500ll cartridge in it is worth more than i paid for it.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • soundfreak1
    It appears to have simular spring 3 way suspension like the thornes and a few others of the day marked rotel Tokyo Japan.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • soundfreak1
    Just rear it is QUAD capable also ( hense the Q in the model #
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • vmaxer
    vmaxer Posts: 5,120
    Sexy table.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • WagnerRC
    WagnerRC Posts: 2,203
    edited August 2015
    congratulation. Enjoy!
    mhardy6647 Posts: 34,998
    edited August 2015
    Looks good to me.
    Every turntable is -- or might well be --Quad capable (even in terms of "CD4" -- compatible, discrete four channel -- true, multiplexed four channel sound on records).
    Matrix quad systems (primarily QS and SQ) should work on any halfway decent tt and cartridge, AFAIK.
    ... so let's talk about CD4 for a moment...
    CD4 records require playback with a cartridge/stylus capable of frequency response up to an ultrasonic carrier frequency used to recover the four-channel data from the CD4 record groove. That multiplex "pilot signal" is somewhere in the neighborhood of 45kHz. Many, most or perhaps even all of the exotic stylus geometries (Shibata, line contact, van den Hul, etc., etc.) that we know and love were designed to tackle CD4.
    The turntable "only" has to bring two things to the CD4 party: an ability to track that CD4 compatible cartridge with some precision and fidelity, and... you guessed it... very low capacitance cables.
  • soundfreak1
    This has cd4 capability and low cap wiring at 75pf according to the manual
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • RamZet
    RamZet Posts: 792
    I've used that model before at a clients house.
    Nice find.
    B&W CM9Classé Sigma
  • soundfreak1
    Ive had a few hours of play time with the Rotel now and i can say I'm surprised at how good it sounds. Even works very well with the denon dl110 cartridge. Short of very lite cleaning it need only a relube for the cueing mechanism. Will put new belt (just because) as it holds speed well.dead quiet running, smooth arm movement and auto stop works effortlessly. Overall a very solid TT.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
