Need Help
There is a seller ''VINTAGE AR'' is their name on Ebay & i read up this seller has sealant i need & im not good with finding 'sellers' can someone help me find his product ? It is sealant im going to use on cloth surrounds on KLH speakers. Thank You Kindly. Randy
Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
MIT BJC Cs1000p Polk Rotation
  • boston1450
    boston1450 Posts: 7,758
    I know how to find a item-put it in decription & hit the search button..... How do i find seller ? Would that be because I use mobile iphone & should use the laptop ?
    Randy-Maine
    by David WMG
  • rooftop59
    rooftop59 Posts: 8,120
    I think this is what u need randy:
    http://stores.ebay.com/VINTAGE-AR-PARTS-AND-SERVICE
    Game Room 5.1.4:
    Bedroom 2.1
  • boston1450
    That looks like the site to put me in the right directions. Thank you very much
    Randy-Maine
    by David WMG
  • vcwatkins
    vcwatkins Posts: 1,992
    edited August 2015
    If that seller or his product doesn't work out, I think this High Tack (thinned) is the stuff I used. It was recommended at the time. Still pliant after 4 or 5 years. Dunno if there's better stuff recommended now though.
  • boston1450
    edited August 2015
    Thanks. I will keep that in mind. Ive read that Vintage AR has some sealant that is close to specs as can get. Ive read you can thin out with different other stuff with good results also. I messaged them & they are on vacation this week & that ls fine by me. Taking a break & enjoying the sunshine while i can up north here :)
    EDIT::: i think i have some Hi Tack in the cabinet i use on the truck. That stuff comes in hand on alot of jobs... What did you mix it with ?
    Randy-Maine
    by David WMG
  • vcwatkins
    I believe it was some sort of lacquer thinner - whatever is on the bottle label.
    I should clarify that the High Tack stuff was the recommendation for KLH's about 5 yrs ago. Don't remember the source, but I don't think it was here because I had not joined at that time. May have been AK. I used it on 6's and 17's. I have never owned AR's, so I don't know if the High Tack goop is appropriate for them. I figured you were asking about the KLH 23's.
  • boston1450
    Yes. Thats the ones im doing. Crossovers should be here Friday & im putting in new binding post & last but not least-goop on the surrounds to keep them airtight. I have some stripping for the crossover plate & i will probably pull that & make sure its air tight. Thanks for the info.
    Randy-Maine
    by David WMG
