New AVR acting weird???
I got this Yamaha RX-V2030 and ran the YAPO or whatever the hell it is called when I got it. Now I ran it again after a little burn in time. Now it says my front L/R are reverse??? I did not change a thing. What's up with that, should I be concerned???
  • afterburnt
    afterburnt Posts: 7,892
    Other than being squirely what wold cause that read? I ran it a couple of times and it showed the correct polarity on the left but now it is showing left and right revesed again???
  • afterburnt
    Help am I gonna splode my speakers???
  • ken brydson
    ken brydson Posts: 8,982
    afterburnt wrote: »
    You need a new hobby. Maybe knitting or quilting ...
  • afterburnt
    edited July 2015
    LMAO! I tried golf but that damned monkey caddy kept breaking my clubs!
  • afterburnt
    I don't drink coffee anymore just green tea...
  • afterburnt
  • PSOVLSK
    PSOVLSK Posts: 5,371
    I'm beginning to think you are aka: polkfarmboy
  • afterburnt
    hey man, now you are just being rude
  • chumlie
    chumlie Posts: 8,658
    My Yamaha used to do the same thing. Double check your wires and pay no attention to Yamaha.
  • Sci-fi Polk Guy
    Sci-fi Polk Guy Posts: 194
    edited July 2015
    I wouldn't worry about it. I had a Yamaha RXV663, and I encountered the same problem. Everything was connected properly, and I still got the same polarity error message. Found out later that it was an error in the Yamaha GUI, so it might be the same problem with the 2030. (Thanks for the posting. I've been thinking about purchasing the 2030.)
    Paradigm 11seMkIII mains, w/ Zu Audio jumpers
    Paradigm CC 450 center, w/ Zu Audio jumpers
    Polk Audio RTi6 surrounds
    Paradigm SE sub
    Sony BDP S5100 blu-ray player
    Panasonic 50" plasma
    Yamaha RX A1000 receiver
    Parasound HCA 1205A amp
    Audioquest Evergreen IC's
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    edited July 2015
    Assuming polarity is correct, then the phase error is caused by reflections from room acoustics. Ignore it or try aiming your mains towards the mic. Otherwise acoustic panels may be required.
  • jeremymarcinko
    However if it sounds good, don't eff with it. Some of those early reflections can add a sense of spaciousness, even though it isn't technically correct.
  • afterburnt
    I got mine for $799 new I thought that was a pretty good deal. Just needed a wifi adapter, it is not built in like the next series.
  • mikeyb128
    mikeyb128 Posts: 2,885
    Didn't you just buy lsim 705? If so it is normal for the yammy to pick them up as reversed polarity due to the crossover design.
    2 channel:
    Theater:
  • Nightfall
    Nightfall Posts: 10,084
    I have noticed this. Some sounds sound like they are coming WAY left or right of me, sometimes behind even. If I move my head forward from the couch just a bit it goes away and sounds like it's coming from the speaker. I like it so I'm not going to change it.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • afterburnt
    I dont have the 705's yet. Maybe it is like jeremy said about reflections because out of four runs It showed one of the speakers ok two times. I got tired of running the set up and just left it as is.
