New AVR acting weird???
afterburnt
I got this Yamaha RX-V2030 and ran the YAPO or whatever the hell it is called when I got it. Now I ran it again after a little burn in time. Now it says my front L/R are reverse??? I did not change a thing. What's up with that, should I be concerned???
Other than being squirely what wold cause that read? I ran it a couple of times and it showed the correct polarity on the left but now it is showing left and right revesed again???
Help am I gonna splode my speakers???
You need a new hobby. Maybe knitting or quilting ...afterburnt wrote: »Help am I gonna splode my speakers???
LMAO! I tried golf but that damned monkey caddy kept breaking my clubs!
I don't drink coffee anymore just green tea...
oh and Becks
I'm beginning to think you are aka: polkfarmboyThings work out best for those who make the best of the way things work out.-John Wooden
hey man, now you are just being rude
My Yamaha used to do the same thing. Double check your wires and pay no attention to Yamaha.
I wouldn't worry about it. I had a Yamaha RXV663, and I encountered the same problem. Everything was connected properly, and I still got the same polarity error message. Found out later that it was an error in the Yamaha GUI, so it might be the same problem with the 2030. (Thanks for the posting. I've been thinking about purchasing the 2030.)Paradigm 11seMkIII mains, w/ Zu Audio jumpers
Paradigm CC 450 center, w/ Zu Audio jumpers
Polk Audio RTi6 surrounds
Paradigm SE sub
Sony BDP S5100 blu-ray player
Panasonic 50" plasma
Yamaha RX A1000 receiver
Parasound HCA 1205A amp
Audioquest Evergreen IC's -
Assuming polarity is correct, then the phase error is caused by reflections from room acoustics. Ignore it or try aiming your mains towards the mic. Otherwise acoustic panels may be required.Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant
However if it sounds good, don't eff with it. Some of those early reflections can add a sense of spaciousness, even though it isn't technically correct.Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant
Sci-fi Polk Guy wrote: »I wouldn't worry about it. I had a Yamaha RXV663, and I encountered the same problem. Everything was connected properly, and I still got the same polarity error message. Found out later that it was an error in the Yamaha GUI, so it might be the same problem with the 2030. (Thanks for the posting. I've been thinking about purchasing the 2030.)
I got mine for $799 new I thought that was a pretty good deal. Just needed a wifi adapter, it is not built in like the next series.
Didn't you just buy lsim 705? If so it is normal for the yammy to pick them up as reversed polarity due to the crossover design.2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
I have noticed this. Some sounds sound like they are coming WAY left or right of me, sometimes behind even. If I move my head forward from the couch just a bit it goes away and sounds like it's coming from the speaker. I like it so I'm not going to change it.jeremymarcinko wrote: »However if it sounds good, don't eff with it. Some of those early reflections can add a sense of spaciousness, even though it isn't technically correct.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
I dont have the 705's yet. Maybe it is like jeremy said about reflections because out of four runs It showed one of the speakers ok two times. I got tired of running the set up and just left it as is.
https://www.youtube.com/watch?v=hd1ciPnTGKg
https://www.youtube.com/watch?v=lyhaTQseKTQ
