I just wrecked my stylus with the magic eraser
  • sucks2beme
    sucks2beme Posts: 5,557
    PFB II ???
  • afterburnt
    afterburnt Posts: 7,892
    gudnoyez wrote: »
    I got my hand slapped here for using what I thought was stylus brush. Oh no, it was the cleaning brush for the RCA cleaning thing
    I remember that it was the brush you use to clean the lint of the Discwasher pad, I'm surprised your stylus survived :#
    Wow Afterburnt a real awesome gesture from Daryll aka (Voltz) a Ortofon Red coming your way. Voltz you the man.
    Daryll IS the bomb! he is sending me all kinds of bonus prizes too!
  • voltz
    voltz Posts: 5,384
    I have been there & done that so glad I can help.
    Figured while I was sending you something I would toss in a record clamp I wasn't using and a couple of Duplicate LP's & a DVD that helps you set up a TT.
    But like Rich suggested maybe if you get comfortable installing a cartridge you may want to try a high output MC cartridge someday... I now using a Sumiko MC Blue point #2 on my TT and really like it.
  • pumpkinman
    pumpkinman Posts: 9,520
    edited July 2015
    voltz wrote: »
    Kindness like this by Voltz is what makes the forum special.
    Thank You Voltz
    P-man
    Because I am The Pumpkinking
  • afterburnt
    Yes first time being a bone head ultimately had a sweet outcome.
  • afterburnt
    I still have cruddy feeling for tearing my stuff up in the first few minutes of the game lol
  • pumpkinman
    Keiko wrote: »
    I quit using liquid cleaners. Some may have chemicals that can actually loosen the glue that hold the stylus to the cantilever. Been using the ME for a few years now and it's kept my stylus squeaky clean.
    That's the reason I quite using liquid stylus cleaner. It never happened to me but I was told the same thing. I also use the Magic Eraser and have never had an issue.
    P-man
  • afterburnt
    edited July 2015
    https://www.youtube.com/watch?v=yZWf6tlvVss
    What a jamoke, 2 years and he still aint wrecked it?
  • boston1450
    boston1450 Posts: 7,453
    Thats what i use & seems to work for me
    Randy/Maine
  • afterburnt
    voltz wrote: »
    Darryl everything arrived safe and sound. Up and running again. I can't thank you enough! If there is anything that I can ever help you with just ask. Great albums too!
    Bruce
  • voltz
    voltz Posts: 5,384
    Awesome! You welcome Bruce.
    gudnoyez Posts: 8,060
    Keiko wrote: »
    oWch! I've always used the safe method when using the ME. Sorry to hear, man.
    I've become accustomed to the pull out method myself :D
    Afterburnt that was fast, well how do you like the Ortofon over that Audio Technica?
  • afterburnt
    Gud it is pretty nice hell of an improvement!
  • afterburnt
    aprazer402 wrote: »
    Afterburnt, If you want, send me a PM with your address and I'll mail you a Discwasher SC-1 stylus cleaner brush, no charge. The photo is of the actual extra brush I would send you. You can use it dry, there is also Discwasher fluid available, you used to put one drop on the brush before you would start at the rear of the stylus and pull it forward through the bristles to clean. Just offering.e10137lzqd99.jpg
    Tim I got the brush today. It looks a lot less hazardous than the "Mr Clean Magic Stylus Destroyer" Thanks if there is anyway that I can return the favor just say so!
  • voltz
    voltz Posts: 5,384
    Just touch it and dont rub it LOL
    BTW AB the ortofon cartridge has replacable stylus without changing out the cartridge each time ...you can get the blue stylus for $100 more and it sounds better then the RED...easy to switch between them
    http://www.musicdirect.com/p-4509-ortofon-2m-blue-replacement-stylus.aspx
  • afterburnt
    thanks Darryl, I probably won't be able to stop myself from buying one lol
  • voltz
    voltz Posts: 5,384
    LOL Sorry Bruce, but be careful...that blue stylus is the one I snapped off after about 15 minutes of using it :'(
  • afterburnt
    afterburnt wrote: »
    Now it sounds really good, added an A31 to my ghetto speakers lol.
  • afterburnt
    afterburnt wrote: »
    afterburnt wrote: »
    Best part is that I can't retire now!
  • afterburnt
    gudnoyez wrote: »
    Keiko wrote: »
    Breaking into some prized old/new albums and I am surprised how well these 70's sound with this Ortofon.
  • voltz
    voltz Posts: 5,384
    afterburnt wrote: »
    gudnoyez wrote: »
    Keiko wrote: »
    Glad your enjoy the Cartridge! I was talking to one of the guys from Acoustic sounds and they are the ones pressing a lot of the newer Vinyls, and told him I had pick up a Pro-ject Debut carbon and it had the Red ortofon on it and ask if I change it out? what should i use?
    He said don't do it.. he felt the Red was a perfect match for the debut Carbon and said to spend the $$$ for a upgrade on a better phono amp before the cartridge.
  • afterburnt
    I am not using the internal preamp in the Teac, I am going straight to the phono input on the AVR. Do you think I would benefit from a separate preamp?
  • voltz
    voltz Posts: 5,384
    that is a sweet little phono amplifier, I liked it a lot and the only reason I change to a different one was it's size is about 9 inches wide and wouldn't fit into my audio rack where I needed it too.
    but external phono amps are normally better, especially over AVR's .. but you should try the one in your Teac also and compare those two. but if your happy then you good.
    The dude in the DVD I gave ya recommends that Phono preamplifier.
  • afterburnt
    Oh well I guess I need one of these too lol
  • afterburnt
    voltz wrote: »
    Darryl I did try the Teac preamp with the original cartridge and like the Yamaha better (I think) I will give it another try when I get home from work today.
  • afterburnt
    What about this one? I know nothing about phono preamps so the numbers mean nothing to me but they are 10% off and I get another 10% off of that.
    https://emotiva.com/products/pres-and-pros/xps-1
  • voltz
    voltz Posts: 5,384
    edited July 2015
    I have not heard anything about that one, and have not heard any Emotiva stuff myself. but here is a link to some that AA carries and for the price of the Emotiva I like the Cambridge 551p that AA has.
    http://www.audioadvisor.com/products.asp?dept=74&val=1
    they do have the Zphono for $199 but you should get it from Skip if you go that way!
  • afterburnt
    Thanks guys Skip is trying to give me some very good guidance and I think is steering me in the right direction.
  • RamZet
    RamZet Posts: 792
    afterburnt wrote: »
    why not the Shure M97xE ?
    I have this unit, what an awesome product.
    B&W CM9Classé Sigma
  • PolkieMan
    PolkieMan Posts: 2,446
    I have one also it's quite good
    RamZet wrote: »
    afterburnt wrote: »
