RCA caps
Wasn't sure where to post this but I guess it's 2 channel related. At this time I have several pairs of RCA plugs unused on my preamp and figured maybe I should get some caps on them. Of course you can spend just a few bucks on 10 or twice as much for half as many. As long as they are snug fitting and made of metal is there really any appreciable difference between them?
Yep, my name really is Bob.
  • drumminman
    drumminman Posts: 3,396
    edited June 2015
    I have an NAD pre with many inputs, and I put cheap RCA plugs I had on hand in all the unused ones. I could hear an improvement in SQ: a bit better clarity. Supposedly the theory behind plugging them is to prevent stray EMI or RFI from entering through the inputs and contaminating the signal.
  • aprazer402
    aprazer402 Posts: 3,449
    I have not used these yet, but am also interested. I have read that you should use a shorting cap, with a center post on RCA inputs, but only caps, without center posts, on RCA outputs. Hope someone else replies as there may be others interested. Thanks.
  • voltz
    voltz Posts: 5,384
    edited June 2015
    My RCA Caps are from Vincent like my Preamp & amplifier, are they better ? I can't really tell yet :p
    but they look good ;)
    F1nut Posts: 52,153
    I use the Cardas Signature version on my 2 channel rigs. Although I can't say I heard a difference, they do no harm and protect the jacks from dust and oxidation.
    The really cheap ones at Audio Advisor or Parts Express (can't remember which) are plastic, not metal. There's an audio business on Audiogon that is selling some metal ones they had made for a really good price, $60.00 for 50 caps. I'll probably get some of those for my AVR.
  • skrol
    skrol Posts: 3,480
    My old Denon DRA-835 came with shorting plugs for the unused RCA inputs as did a Pioneer Elite amp that I had. The did make a difference in reducing the background noise.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • muncybob
    muncybob Posts: 3,280
  • aprazer402
    Here's an AK discussion link on caps and shorting plugs. I would like a more definitive answer also. Why risk using the input shorting plugs if the caps will reduce possible floor noise as well. http://www.audiokarma.org/forums/showthread.php?t=513861
  • Speedskater
    Speedskater Posts: 495
    Nether covers nor shorting plugs at the inputs will accomplish anything!
  • voltz
    voltz Posts: 5,384
    but they look good :) no reason I see not to use them B)
  • vmaxer
    vmaxer Posts: 5,121
    Yes they will.... Take money from you.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Speedskater
    I stand corrected:
    a] Caps will do something...keep dust off and out of the connectors...that's something.
    b] they look good no reason I see not to use them
    c] Yes they will.... Take money from you.
    All of the above are true.
  • muncybob
    I'm not expecting any change in sound but would welcome any perceived improvement. For the small investment I need to make, keeping the jacks clean is worthwhile to me.
    F1nut Posts: 52,153
    d] You'll get a warm fuzzy feeling knowing they are back there. B)
  • marvda1
    marvda1 Posts: 4,965
    Puritan PSM156
    txcoastal1 Posts: 13,519
    That's what I told the wife... That didn't work
  • skrol
    skrol Posts: 3,480
    edited July 2015
    Perhaps it depends on the equipment. The Pioneer Elite M91 had noticeably less background noise when the plugs were in the unused jacks. The Denon too but not as much difference. It would seem that the manufacturers included the things for good reason.
    This is a little different but my Parasound pre-amp has background noise if nothing is connected to any of the inputs. This drove me nuts troubleshooting. Then I connected a CD player and the noise went away no matter what input was selected.
    Stan
    Main 2ch:
    HT:
    Other stuff:
