Converting FLAC to mp3
I want to put some music on an sd card. I have all of my cd's saved as FLAC's and they are again buried in the bunker. I was hoping that EAC could convert the files but I don't see that function. Is there any free software or some indigenous windows program that will do it?
  • afterburnt
    afterburnt Posts: 7,892
    No I am not crazy yet. I want to try it in my car which I highly doubt would play a FLAC file.
  • eeagle
    eeagle Posts: 226
    I use Foobar2000 to do most conversions.
    Here's a link to how
    SDA SRS 1.2
    Adcom GFA-5802
    Adcom GFP-750
    Sony DVP-NS999ES
  • westmassguy
    westmassguy Posts: 6,850
    Have you tried playing a FLAC file in the car? Many devices do recognize and have the proper codec for FLAC. Even at their highest bitrate, mp3s suck.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • afterburnt
    west I did try it and it does not work.
  • afterburnt
    eeagle wrote: »
    I will give this a try
  • afterburnt
    Drove 1200 miles listening to 256 bits and boy did it suck but maybe it my car, I never even heard a cd play in it yet.
  • StantonZ
    StantonZ Posts: 454
    afterburnt wrote: »
    It's the car: I play 160 kbs MP3s in my car and it sounds OK (I EQ the **** out of my car system). I play FLACs @home (no EQ at all) so I know what "good" sounds like. There are many free MP3 encoders/decoders, but you can go directly from FLAC->MP3 with something called SOX (http://sox.sourceforge.net/).
    (2) Polk RC80i (Top Middle)
    Polk CS300 center channel
  • VSAT88
    VSAT88 Posts: 1,373
    Foobar 2000. Yes, Excellent program at a price that is affordable...Free !
  • rooftop59
    rooftop59 Posts: 8,120
    edited June 2015
    I rip all my CDs flac using media monkey, then it gets automatically uploaded to google music cloud, which automatically converts them to 320 Mbps MP3. Use an app called play music to stream my entire library from my iPhone while in the car. And u can download those files to ur phone for when the reception is bad.
    I have found that in the car-especially on the freeway-I cannot tell the difference between flac and 320, though I certainly can at home.
    Game Room 5.1.4:
    Bedroom 2.1
