Converting FLAC to mp3
afterburnt
I want to put some music on an sd card. I have all of my cd's saved as FLAC's and they are again buried in the bunker. I was hoping that EAC could convert the files but I don't see that function. Is there any free software or some indigenous windows program that will do it?
No I am not crazy yet. I want to try it in my car which I highly doubt would play a FLAC file.
SDA SRS 1.2
Adcom GFA-5802
Adcom GFP-750
Sony DVP-NS999ES -
Have you tried playing a FLAC file in the car? Many devices do recognize and have the proper codec for FLAC. Even at their highest bitrate, mp3s suck.Home Theater/2 Channel:
dhsspeakerservice.com/ -
west I did try it and it does not work.
I will give this a try
westmassguy wrote: »Have you tried playing a FLAC file in the car? Many devices do recognize and have the proper codec for FLAC. Even at their highest bitrate, mp3s suck.
Drove 1200 miles listening to 256 bits and boy did it suck but maybe it my car, I never even heard a cd play in it yet.
afterburnt wrote: »Drove 1200 miles listening to 256 bits and boy did it suck but maybe it my car, I never even heard a cd play in it yet.
It's the car: I play 160 kbs MP3s in my car and it sounds OK (I EQ the **** out of my car system). I play FLACs @home (no EQ at all) so I know what "good" sounds like. There are many free MP3 encoders/decoders, but you can go directly from FLAC->MP3 with something called SOX (http://sox.sourceforge.net/).
Yamaha RX-A2050 AVR (5.1.2); LG OLED77C2 4K TV(4) Polk Monitor 10B's w/SoniCaps, Mills, and RDO-194 tweets (R/L F/R)(2) Polk RC80i (Top Middle)Polk CS300 center channelKlipsch SPL-120 subwooferAnalog: B&O TX2 Turntable, Nakamichi Cassette Deck 1Digital: Pioneer CLD-99 Elite LD, Panasonic DMP-UB900 UHD Blu-RayBedroom: Arylic Up2Stream AMPv3 driving Polk Monitor 4's w/peerless tweets -
Foobar 2000. Yes, Excellent program at a price that is affordable...Free !
I rip all my CDs flac using media monkey, then it gets automatically uploaded to google music cloud, which automatically converts them to 320 Mbps MP3. Use an app called play music to stream my entire library from my iPhone while in the car. And u can download those files to ur phone for when the reception is bad.
I have found that in the car-especially on the freeway-I cannot tell the difference between flac and 320, though I certainly can at home.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Bedroom 2.1 Harmon Kardon HK3490; Bluesounds Node N130; Polk RT25i; ACI Titan Subwoofer
