MF KW500 Integrated - any experience?
Joey_V
Joey_V Posts: 8,603
Just put an offer on one of the KW500 Integrateds on audiogon, hopefully the guy accepts and I take delivery next week. Anyone here has experience or opinion on this integrated? I've always watched from the sidelines as this always seemed like a good value. My brother has the M6i integrated and it sounds very good.
Hopefully he accepts my offer.
«13
    F1nut Posts: 52,100
    You'll need a dedicated 10 gauge, 20 amp line and a good power cord to feed that monster otherwise you won't get what it's capable of. It also likes to be left on 24/7.
  • Erik Tracy
    Erik Tracy Posts: 4,673
    Jealous.
    Hope you get it.
  • vc69
    vc69 Posts: 2,500
    edited June 2015
    I'd put that thing at "end-game" status, from all I've read or heard about it. No hands-on experience to offer, though. Good luck!
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • Joey_V
    Joey_V Posts: 8,603
    edited June 2015
    Have dedicated lines covered stronzo in the main room but I am planning this to go into the secondary.
    Once I move them to the secondary room, I will install another dedicated line. Shouldn't be too hard.
    And I listen to you stronzo
    Post edited by Joey_V on
  • Joey_V
    Joey_V Posts: 8,603
    Erik Tracy wrote: »
    Jealous.
    Hope you get it.
    I'm excited!!
  • Joey_V
    Joey_V Posts: 8,603
    Figured since you had it, it has to be pretty good.
  • Joey_V
    Joey_V Posts: 8,603
    Hey Sean,
    I did not know there was a KW550 integrated....
    I am not looking for end game, I am looking for something that works well and is reliable. This is for a secondary system and at that price, difficult to beat if all the reviews are correct.
    In a few years, when I have big boy money, we'll get to some really really good no holds barred stuff.
    Joey
  • Joey_V
    Joey_V Posts: 8,603
    PS
    The seller rejected my offer, we will see what he says about the 2nd offer... crossing fingers.
  • Joey_V
    Joey_V Posts: 8,603
    Zero wrote: »
    Will this be used with the Strads?
    No that is not the plan. The strads will get Cary and then I will evaluate. I will likely roll in some really nice SS amps to pair with a tube pre and see how that does on the future Strads. I am thinking either let me try a pair of Parasound JC1, Classe M600, Krell 402e Evolution, or some high powered macs like the MC1.2kw or the 601.
    Then I will decide which direction the main system will go. It is entirely possible that I keep the Cary 211fe regardless and have a 2nd set of SS amps.
    UNLESS I buy some heavy duty gear like some Dagostinos or soulution and I will have to sell the 211fe for sake if finances.
  • audiocr381ve
    audiocr381ve Posts: 2,588
    Zero wrote: »
    Joey,
    It looks like I'll need to make a correction. I haven't heard the 500. Only the KW-550.
    I suppose it all hinges on what you're after Joey. If I had to be brutally honest, the KW-550 wouldn't even earn a spot on my top-20 list of favorite integrated amps - and I actually like Musical Fidelity.
    Don't get me wrong. I understand why so many people love this product. It's tough to hate on a piece that's built like a f***king M1 Abrams tank, can drive just about any loudspeaker ever made, is punchy as all get out, can create a massive soundstage, and possess the kinda 'forward' voicing that a lot of people love. I get it.
    Still, to me, the KW-550 sounded like a component that was voiced to walk the line between musicality and transparency - and fended up failing to do wither. The midrange and bass sounded a touch bloated to my ears, and the treble sounded gritty and transistory. No matter how hard I tried, I couldn't dig the sound.
    Anyway, that's my experience with the piece. I readily admit that there is probably a combination that would make me really love the KW-550. Either way, all of my banter may be neither here nor there. If my memory serves me correctly, the 500 supposed to be less colored sounding than the 550. If that's the case, then you may very well be onto a winner. I'm not sure how the 500 will match up with your B&W's. When I heard the KW-550 on a set of 802D's, well, .. erm.. yeah. hehe Anyway, at least it has the name recognition and the bling factor that you tend to go for, so that's a start. :D
    Any thoughts on the M6i? Don't mean to derail the thread at all but I may be checking one of these out soon.
    F1nut Posts: 52,100
    The kW500 nor any of the other MF pieces I've heard do not sound anything like the description of the kW550 above.
  • Joey_V
    Joey_V Posts: 8,603
    Zero wrote: »
    Joey,
    Brother has it and it sounded good enough to get me to look at more MF pieces.
    edited June 2015
    Me neither, that description sounds like it was broken or something else in the system was amiss.
    Joey,
    Someone else here has the M6i and loves the darn thing, maybe they'll chime in. If SS amplification is your goal, Pass has to be near the top, McCormack, MF. Ted had the MF superchargers before finally going all tube with the Wolcotts. As I recall, he liked the superchargers better than the Bat vk-600. Obviously there are other choices, but no so down to earth pricing.
  • Joey_V
    Joey_V Posts: 8,603
    tonyb wrote: »
    Joey,
    Yeah my brother likes his m6i quite a bit
  • Erik Tracy
    What's the forum opinion on the Tri Vista 300 int amp?
    F1nut Posts: 52,100
    Erik Tracy wrote: »
    I thought it was excellent.
    Erik Tracy wrote: »
    You'd be hard pressed to find anyone who heard one and said they didn't like it. To me, the 500 has a more refined sound but still maintains that MF house sound.
  • Joey_V
    Joey_V Posts: 8,603
    Guy is playing hardball, doesn't want to deal. He wants 2900, I wanted it for 2350.. hmm...
    Worth it? New tubes inside and has extra tubes... 2nd owner.
    Thoughts?
    He's playing the "I'm not aching for money" card...
  • Erik Tracy
    Is this one of the two KW 500s on audiogon?
    If so, his price is quit a bit lower than the other listing. Maybe he's playing firm cuz of his initial price in comparison to the other.
    Any historical data on previous sales to know if his price is 'right'?
  • brianle
    brianle Posts: 572
    Joey_V wrote: »
    Thoughts?
    $2900 seems a bit high to me. I had the same experience with the kw500 as zero had with the kw550. Sold it within couple months
    Does that work for marriages too ? :)
    F1nut Posts: 52,100
    The price is right.
  • Joey_V
    Joey_V Posts: 8,603
    tonyb wrote: »
    Bahahahha
  • Joey_V
    Joey_V Posts: 8,603
    The price is right.
    Jesse
    The question is - is the price adequate at 2900 or a great deal?
    F1nut Posts: 52,100
    For the condition the price is on the money. I've seen other ones with scratches and/or nicks go for a bit less.
    The extra tubes mean nothing as they are inexpensive.
    Personally, I think the M6500i is where you need to be.....a monster.
  • Erik Tracy
    I need my soap opera update 'fix'....what is the haps???
    Did he or didn't he, the sands of time are running out!! :)
  • Erik Tracy
    Pssstt....Joey....if you didn't get the KW - go check out the M6i in the Flea Market!
  • brianle
    brianle Posts: 572
