How important is equal wire length?
McLoki
I am in the process of upgrading my home theater and have a question. Should all wire lengths be the same, or be made as short as possible to reach the speaker? (within reason of course) I am running a 5 channel system and lengths are from my reciever to the speaker (as the cable runs)
Center Channel about 23 feet of cable
Right Channel about 18 feet of cable
Left Channel about 16 feet of cable
Left rear channel about 30 feet of cable
Right rear channel about 15 feet of cable
Based on that info, how long should I make my cables?
(I would still set the speaker distances correctly in the AVR based on distance to listener not cable distance)
Thanks for your input,
Michael Hand.
Michael Hand.
Post edited by McLoki on
First things first...Welcome to the forum!!
Your wires do not need to be equal. Keep all of the wires as short as possible and you'll be fine.
Wire size is going to have a greater impact than equal length cables. I think you'll find that most folks are going to recommend 14ga for the surrounds and 12ga for the mains and center speaker. They are doing the lions share of sound reproduction in a multichannel system and will benefit from a slightly larger wire.
You're correct in setting the speaker distance via the receiver. Some people get a bit confused by this parameter and fail to set their suystem up properly as a result.
If you don't already have one, the best investment you can make for your HT is an SPL meter from Radio Shack. Calibrating a system by ear isn't very accurate. -
Michael, as Frank indicated, keeping wires equal in length is meaningless at the distances involved in the home. Audio signals travel along the wire at nearly the speed of light and the difference in length would have to be miles before an audible difference in timing between speakers would occur. At the distances you mention, no audible difference in loudness between the speakers(which could easily be balanced anyway)would take place either. Allow a little extra length for the sake of flexibility in placement; a wire a little too long does no significant harm, while one that's too short has a disastrous effect on sound quality. For your runs 16ga would be adequate, but using 14ga or 12ga is okay if you don't mind the added expense and the somewhat more difficult to handle thicker wire.
Now if peeps say 12 AWG is god for fronts the kimbers I bought yesterday are only 14awg , and how can you have a run that is too short it has to reach the receiver and speaker...therefore as long as it reaches both it can't be too short
John K. is correct (as usual) about wire lengths. For longer runs, I suggest going to Home Depot and getting their bulk "extension cord" wire - usually clad in orange or yellow. It's flexible and rather easy to snake thru walls, etc.
Personally, I use 10-AWG Blue Jeans Cables wire for my mains - and have run 14-AWG "extension cord" through walls to my surrounds.
Please note - when I say "extension cord," I don't mean those wimpy liddle brown or white things with plugs - I'm talking round, colorful wire on the big bulk spools! (grin)
Good luck - you'll be fine. Larry R. -
Willow - I think friend John K. had tongue firmly in cheek when he wrote about "too short" having disastrous effect on sound quality. Sound seldom jumps inches or feet from a wire-end to a speaker terminal! (grin) LR
You're over thinking.Originally posted by Willow
14awg is fine. There are no set rules, only guidelines.
I used the 4vs for a long time and it's 13awg. I added a set of 8pr to the subs in my RT1000i's and noticed a slight increase in bass but nothing drastic.SDA-2a, Anthem Pre-2L, Anthem Amp 1, MF A324 DAC, Rotel RCD1070
Senn HD650 Cardas, Mapletree Audio Ear+ HD2, Kimber KS1030, Bel Canto DAC2, M-Audio Transit, Laptop. -
I can't wait to see(hear) the difference I hooked them up last night but only listened to an episode of Supranos on DVD I found the center to be more clear and clean but the mains nothing yet
I have Kimber 4PR and it blew the snot out of the 12ga Home Depot extention cord in my rig. I'm not a "wire makes a BIG difference" kind of guy but the difference was obvious in this instance. Another forum member (gmorris) was there and heard it too, it was an immediate difference when switching from Kimber to HD wire. The HD wire was like throwing a blanket over my speakers.
The other thing that the Kimber has going for it is that it has a dialectic to shield the cable, keeps the signal clean.Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
As I mentioned I noticed a better sound out of the center but not yet out of the mains I too Have gone from HD spool 12awg cable to the kimbers...did you find a "break in preiod" I am was a " A cable is a cable" thinker/ beleiver as well
If the cables are used, there probably won't be a burn in. As for your mains, because most of the dialog in movies come from the center you'll probably notice most of the difference there.
If you listen to music, that's when you'll notice a difference for your mains.SDA-2a, Anthem Pre-2L, Anthem Amp 1, MF A324 DAC, Rotel RCD1070
true !! tonight my wife is going shopping so I will play around with it !! can't wait...I'm excited to see if cables really make a difference..so far yes on my center....
The thing about cables is that they do make a difference, but a lot of it depends on the gear they connect. One can't expect wires to make a silk purse out of a cow's ear.
Larry.....I enjoyed your tongue in cheek, "John K. is correct (as usual)" comment. WAAAAAAAAAAAAAAAAAAAAPolitical Correctness'.........defined
President of Club Polk -
The HD 12awg speaker wire also has dielectric around the wire.
2 cents -
Cool, I did not know that. If I ever need some long runs I'll definitely be checking out the HD wire again.Originally posted by PolkThug
2 centsSony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
that's where I am headed this weekend for new runs for my rears are we talking HD spool house brand or carol brand
It is HD extension cord. It's not actually HD speaker wire. It is made to be used as heavy duty extension cord but people use it as speaker wire because "wire is wire", right?Originally posted by Willow
The stuff comes in yellow or orange...Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
WTH ??
so I go in and ask for 2 prong extension cord ??? -
nope, it's 12-3 extension cord wire that is sold by the foot. it has three 12ga wires in it. you use two of the wires and ignore the third. It should be next to all the other wire (speaker wire included). the outer jacket of the extension cord wire is orange or yellow.Originally posted by Willow
WTH ??
so I go in and ask for 2 prong extension cord ???Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
can I remove the orange and yellow and just use 2 cords ??? I need to run it under the carpet along the wall can't be thick at all or it will look dumb and I will get a negative on the WAF
Nope - Willow - it's nice and round - too big to go under carpet. And no, you can't (shouldn't) strip off the insulation - you'll be left with individual wires, which will prove, uh, "uncomfortable."
For under-carpet runs - try using the labeled "speaker wire" that HD and even better Lowe's sells - it's got clear jacket, and is flat like a "regular" extension cord. LR -
thats what I have now. cept it's 18awg and non-oxy free, so I will get oxy-free 16 awg
Willow - you can go **** trying to find out if wire is "oxy-free." Most isn't - and many sites post that it's just not that important. I'm not gonna argue that - period! (grin)
But I'd go with 14-gauge if you've got runs of over 15 feet. Less, well, 16-gauge might be OK - I like nothing smaller than 14.
Good luck running under-carpet! Tough job! Larry R. -
This read should help.
http://www.audioholics.com/techtips/audioprinciples/interconnects/Cable-Breakin.htmlpolkaudio SRS (rdo194 x 8)
Dodd ELP (separate power supply)
JC 1 blocks ( strapped )
Rega Apollo
MIT (speaker cables) Outlaw (ICs)
polkaudio SDA2(rdo194x4) (front) polkaudio CRS (rdo194x4)(rear) polkaudio 400i (center)
B&K 505
Samsung LCD
VIP 622
HSU STF-2 -
I'd say that read doesn't help.Originally posted by read-alot
http://www.audioholics.com/techtips/audioprinciples/interconnects/Cable-Breakin.htmlSDA-2a, Anthem Pre-2L, Anthem Amp 1, MF A324 DAC, Rotel RCD1070
read it before...thanks though...
What a crock of ****!Political Correctness'.........defined
An inch or foot or two doesn't make much difference, but I would even up the lengths of your left and right rear channels.Originally posted by McLoki
The reason for having equal lengths of wire for corresponding speaker pairs (eg. match left and right main lengths, match left and right rear lengths), is to match the resistance of the wires.
P.S. PolkThug, I like your 2 cents
Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70 -
http://www.nytimes.com/library/tech/99/12/circuits/articles/23down.html
Maybe this is a better read since it quotes Paul from Polk.polkaudio SRS (rdo194 x 8)
Rega Apollo
B&K 505
Samsung LCD
VIP 622
HSU STF-2 -
That is a better read and I have read it before. Make note that the percent ratio of the cable cost to the systems mentioned is the suggested 10% of total cost.
"We are talking subtle differences, but that is what the high end is all about,"
No truer words have been spoken about audio.Political Correctness'.........defined
ReadAlot - Are you on a personal crusade? Neither side is right regardless of how many "scientific" articles are written.
If it's audio jewelry, than millions must be wrong, not just a couple of us on the forum. And really...who gives a crap. It's what the individual experiences, not the masses.
If you put no effort to make your own semi-rigid experiment and assessment, than how can you say anything but cut and paste words?CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
