Speaker wire sound
  • vmaxer
    vmaxer Posts: 5,120
    How to start an argument on this forum:
    Post an opinion or experience.
    Wait for X to respond.
    Every time >:)
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • ken brydson
    ken brydson Posts: 9,001
    vmaxer wrote: »
    Every time >:)
    Subject doesn't even matter...
    mhardy6647 Posts: 34,994
    edited June 2015
    watch this space -- coming to a theatre near you...
  • vmaxer
    vmaxer Posts: 5,120
    vmaxer wrote: »
    Every time >:)
    You are correct, can't have anything peaceful with him around.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    tonyb Posts: 33,072
    Tony, your 1st response was awesome. Now for me as a former alarm installer doesn't Ohm's law play a major factor in all of this ? With gauge of wire,length of runs, materials used and I'll throw in efficiency of the speakers and how clean your amp is and the sources being used. My real world experience,I went from Home Depot 14 gu. clear to Audio Quest 14 gu, and settled on BJC Belden 12 gauge for my 2Bs and my TF 350s. Did I hear a difference,yes each time but this is all my wallet will allow.
    Yes Lew, we are all aware of Ohms law, but there is simply more to a cable than that. You yourself heard a difference in every cable you tried, that's all that matters isn't it ?
    As far as your wallet goes, Lew...we all do the best we can with what we can afford, no shame in that pal. Good sound can be had at any price point and that's a fact. As long as your ears tell you your in heaven, rock on with what ya got buddy boy.
    Seems to me your doing just fine anyway. Your trying different things here and there and that's the name of the game. Keep your eyes peeled for those deals and pounce when you can. We've all been where your at.....some of us still are, so what....enjoy the tunes.
  • mantis
    mantis Posts: 17,364
    edited June 2015
    nbrowser wrote: »
    don0 wrote: »
    What are the characteristics of speaker wire that makes them sound different from other speaker wire?
    Let me answer with key points, shall we?
    Construction
    Gauge
    Terminations
    Dielectrics (insulators)
    Length
    Conductor material
    All do something or other to the signal delivered to the speaker from the amplifier. What's best? We don't know. What's worst? Again we don't know but cable makers are trying to come up with new and exciting ways to 1, improve sound and 2, empty the wallter. That's my one and only contribution to this thread. Take as you wish :)
    This is basically what makes a cable "sound" different then another.
    So in a given system, you need to have the proper gauge of wire to pass the signal from the amp to the speaker.
    It has to be a proper length for given factors
    It has to be properly terminated
    Then the Materials used and symmetry or relationship to conductors have also play a huge roll here.
    Personally and professionally speaking
    Speaker wire has a job to do. It's not supposed to "sound" like anything rather then pass the signal along it's way so the speaker can replay the signal it was given from the given source.
    So looking at it deeper what happens is a lot of speaker wire that changes the sound is taking something away from the signal or bringing back things that the speaker wire that was used in given system could not replay. It's really that simple.
    Speaker wire should not be used to "tune" a system rather be used to "preserve" the system.
    There are so many factors to come into play when recreating or replaying an audio experience. Getting the cables right is probably the easiest when you have the right information.
    You have to start with the basic fundamentals and standards.
    Dan
    tonyb Posts: 33,072
    I dunno Dan, to me the "right information" is what my ears tell me, nothing else matters, science wise, or anything else wise.
    tonyb Posts: 33,072
    What exactly does a "cable-less sound"....sound like ? Would that not be different to each individual ? Therefore....how can one cable apply to so many ? Doesn't make sense to me.
    F1nut Posts: 51,747
    That idea falls flat on it's face when one realized that cables are no different than tubes, DAC's, cartridges, amps, CDP's, pre amps, etc. Each has its own flavor and therefore are used to "tune" a system. To think otherwise is simply naive.
  • ken brydson
    tonyb wrote: »
    Tried running my rig cable-less. Couldn't hear a damn thing. Maybe it's just me...
  • ken brydson
    xcapri79 wrote: »
    tonyb wrote: »
    Just watch a tube amp behave when a speaker cable becomes disconnected. Ouch!
    Oh, humor now...
  • BlueFox
    BlueFox Posts: 15,251
    xcapri79 wrote: »
    You said it not me, however some may consider your comments to be a Freudian slip. ;) Failing prey to the placebo effect doesn't mean someone is psychotic as you put it. It means they are human and perhaps a little gullible.
    No. You and your quack psychiatry said it. There is no such thing as a placebo effect in audio. That is simply something someone made up, and the audiofools run with it. You use that all the time. According to X, nobody hears a difference with cables. It is all imagined.
  • ken brydson
    xcapri79 wrote: »
    Oh, humor now...
    Yes it goes along with a nice cold beer. :D
    Need more than a beer to agree with your line(s) of BS. Time to move on sparky...
  • ken brydson
    xcapri79 wrote: »
    It is just plain old good advice based on time tested, solid engineering principles, education and experience. Thank you.
    **** me...
  • PSOVLSK
    PSOVLSK Posts: 5,379
    DSkip wrote: »
    Again, theory and reality very seldom walk hand in hand.
    In more than just cables. How are some of those educational theories you learned about working out for you in reality? ;):D
    nooshinjohn Posts: 25,910
    xcapri79 wrote: »
    **** me...
    I would rather have my wisdom teeth removed via a jackhammer than read X's posts...
  • PSOVLSK
    edited June 2015
    Zero wrote: »
    Welp, I'd say this thread has run it's course. Hopefully the OP is satisfied with the information within these pages. Meanwhile, I think it's time to move on..
    Agreed. He just needs to read your post from Page 2 and be done with it. Good, unbiased info you provided.
  • As I previously pointed out, no end to this debate. Am with people who hear a difference, experienced it first hand.. At the end of the day like many have said, it's bout getting a good clean signal to the speakers and so just narrow your choices down to 2-3 different cables and take bout 3 meters of each home. Test each for atleast 3 hours each and stick with the one that you like.
    When we tested the monster cables vs wire world cables we could hear the difference on the B&W 683's but not the JBL set. At the basic level its all bout how sensitive the speakers are and how cleanly the amp or avr could deliver the signal. And the cables do play a vital role in delivering that signal to the speakers so I don't think it's pseudoscience when people claim a certain cable does better than others. IMHO test it out for yourself, make a first hand comparison and dont start another cable discussion!
  • headrott
    headrott Posts: 5,496
    edited June 2015
    xcapri79 wrote: »
    steveinaz wrote: »
    Wire is a component, much like a resistor, capacitor, or inductor. A very simple component, but a component none the less; and as such shouldn't be dismissed as unable to change the tone of music passed thru it. To say that cabls don't matter, is to say that all wire is 100% transparent, no?
    Properly sized competent wire should be audibly transparent. Yes and it doesn't need to cost hundreds or thousands of dollars to achieve this for a good typical home system.
    Tone controls should be on one's preamp or integrated amp where they belong. :)
    Adding resistors, capacitors and inductors costing a few dollars into a box and connecting this to a speaker cable and then charging several hundreds or thousands of dollars for this contraption may be great for the seller but unwise for the educated consumer. ;)
    I am guessing you are referring to MIT cables here?
    Have you ever seen the internals of the MIT wire used in their shotgun cables? I can say that I have as I constructed my AI-1 cables from MIT wire. This MIT wire is some of the most complex and required some of the most R&D out of any wire I have personally seen. I have constructed cables using a number of different wires, and the MIT Shotgun (and any MIT wire using the "network boxes" you were referring to) is much much more than the boxes the wires are attached to. That is fact, that I have personally seen. I know of others on the forum that can attest to this fact as well.
    Please go buy some MIT shotgun wire and take a look for yourself. Then please come back with a fully educated opinion about MIT speaker wires being comprised of some "resistors, capacitors, and inductors costing a few dollars and connecting this to a speaker cable and then charging several hundreds or thousands of dollars for this contraption may be great for the seller but unwise for the uneducated buyer."
    If you have not seen the inside of the Shotgun wire (not just the boxes), the uneducated buyer would include you as well, no? (This is absolutely not an insult, but a fact, if you have never constructed a cable using the Shotgun speaker cable).
