What Speaker Cable Do You Use?
No discussion about why you use them or what you've used in the past or what you're hoping to use in the future. A simple answer of what speaker cable you currently use is all I want to know (a link to said cable is okay as well).
http://www.douglasconnection.com/Custom-Made-Furez-12AWG-Bi-Wire-OFHC-Speaker-Cables-DCF124BW.htm
  • Nightfall
    Nightfall Posts: 10,084
    afterburnt wrote: »
    Village Idiot of Club Polk
    tonyb Posts: 33,072
    Right now I have Acoustic Zen Satori speaker cables, a combo of interconnects ranging from Analysis plus crystal ovals, Bogden Goldy, Grover zx+. Looking for a good priced Acoustic zen matrix 2 or silver.
    Previously had Reality cables as speaker cables and liked them a lot too.
    gudnoyez Posts: 8,161
    MIT Terminator II, and Signal Ultras
  • [Deleted User]
    [Deleted User] Posts: 1,394
    PSOVLSK wrote: »
    Kimber. Look for the link yourself, it is the path to Enlightenment. Hehehe
  • Hermitism
    Hermitism Posts: 4,329
    Dual-purpose system Music/HT
    Front three, Doug's Furez DCF124BW with Furez TST series non-plated copper bananas. Currently using older clear coats for surrounds.
  • bryantspaint
    bryantspaint Posts: 114
    Audioquest cv-8
  • PSOVLSK
    PSOVLSK Posts: 5,380
    halenhoang wrote: »
    PSOVLSK wrote: »
    I can't afford anything you're using anyway :D:p
  • Moose68Bash
    Moose68Bash Posts: 3,843
    edited June 2015
    Morrow SP7 bi-wire with bananas in main system.
    Supra Rondo 4x2.5 DIY w/Furutech bananas in second system.
    SCompRacer Posts: 9,112
    edited June 2015
    Harmonic Technology Pro 9+ internal bi-wire for the nethers posts, Harmonic Technology Pro 11+ on the upper posts, just cause I had them. Same wire, just single runs on the Pro 11+. Otherwise it would be jumpers. HT changed hands so I can't get matching terminations/heat shrink for the internal bi-wire (both wires per polarity same termination) to make them bi. I didn't want to lessen their value with non oem parts.
    nooshinjohn Posts: 25,916
    Douglas connection here. The best value in ultra high performance cables in my opinion...
  • DarqueKnight
    DarqueKnight Posts: 6,765
    Monster Cable Z2 Reference (home theater and office systems)
    Monster Cable Z3 Reference (master bedroom system)
    PS Audio Xstream Resolution Reference (2 channel system AI-1 interface)
    AudioQuest Everest (2 channel system speakers)
  • headrott
    headrott Posts: 5,496
    Alpha Core Goertz MI-2 Python (for HT)
    MIT Shotgun S1's for 2 channel
    F1nut Posts: 51,751
    MIT Shotgun's in 4 rigs. Who knows what in the shop, which is generally too noisy to matter.
  • deronb1
    deronb1 Posts: 5,021
    25 yr old 12 awg Monster.
  • mrloren
    mrloren Posts: 2,474
    Doug's Furez for front 3, some arrow crud (home builder installed it) for surrounds.
    The bedroom HT is monoprice for all 5.
  • [Deleted User]
    [Deleted User] Posts: 10,716
    smokin' Op's!
    MIT2 bi-wire for 2 channel and
    Audioquest 33's for the fronts for 5.1/HT
  • vcwatkins
    vcwatkins Posts: 1,993
    Den: MIT S3
    HT: AQ CV8
    Rip/Demo: MIT AVt3 / MIT S3
    Beach: MIT T2
  • MrBuhl
    MrBuhl Posts: 2,419
    Canare 4s11 with the Nakamichi 'nanners here.
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • pumpkinman
    pumpkinman Posts: 10,232
    Van den Hul MC D-352
    This twin lead brown metallic colored speaker cable is designed to provide a very high transfer quality at a moderate price.
    Each lead is made of 296 x 0.15 mm. Matched Crystal (MC) high purity OFC strands with a dense and very pure silver coating.
    Covering the two conductors an extra layer saturated with Linear Structured Carbon ® is applied to improve the sonic performance and to transform the radiated magnetic field into an audio signal again.
    The cable jacket is made of our HULLIFLEX ® 3, a very flexible and mechanically superb insulation material.
    The resistance per lead is: 0.34 Ohm/100 meter.
    Total metal cross-section area for each conductor is 5.23 mm², equalling AWG 10. The capacitance between the 2 leads is: 32.5 pF/meter.
    Because I am The Pumpkinking
  • tophatjohnny
    tophatjohnny Posts: 4,189
  • Jimbo18
    Jimbo18 Posts: 2,349
    KnuKonceptz with Sewell nanners.
  • chumlie
    chumlie Posts: 8,658
    MrBuhl wrote: »
    Same here.
  • marvda1
    marvda1 Posts: 4,943
    edited June 2015
    mg audio design planus 2 speaker cables (discontinued) planus Cu2 interconnects.
    http://www.mgaudiodesign.com/
    i also love the straley reality speaker cables. i have a pair if you want to give them a try.
    http://www.realitycables.com/
    Puritan PSM156
    tonyb Posts: 33,072
    SCompRacer wrote: »
    Excellent choice there Rich, and hard to come by on the used markets I might add, and for a good reason. Looking at some HT prosilways IC's myself.
  • Erik Tracy
    Erik Tracy Posts: 4,673
    MIT Shotgun S2s for mains, Kimber in-wall for center and surrounds
  • dkfreebird
    dkfreebird Posts: 1,186
    Kimber pr8 and Canare 4s11.
    Polk 1.2tl's Modded with dreadnought
    Musical Fidelity M6Si
    North Star Intenso Dac
    Auralic Aries Mini Streamer
    Oppo 103
    Pangea PC
    Wireworld Equinox 7 interconnects
    Wireworld Equinox 7 Speaker Cables and Jumpers
    Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5 peerless,Polk R200,McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre
    tonyb wrote: »
    Thanks. I bought them used in 2006, beat that depreciation. I had the Mk III Pro Silways once upon a time. IIRC they had a mix of silver and copper wire.
  • WagnerRC
    WagnerRC Posts: 2,203
    Satori cables here too.
  • voltz
    voltz Posts: 5,384
    my PC/2 secondary 2 channel room - Signal cable ultra bi-wire
    My HT system is Douglas Connection's Custom Made Furez 9 AWG OFHC Speaker Cables!
    My current 2 channel CRS system ->Analysis Plus Black Mesh Oval 12's which I will be using the same cable for my CRS+'s Interconnect cable with speakons coming from a Dreadnaught Dave's making for me.
  • mantis
    mantis Posts: 17,374
    I use Audioquest Rocket 44's Terminated in Silver Bananas.
    http://www.audioquest.com/rocket-series-speaker-cables/rocket-44
    Dan
