SVS cylinder or a Polk PSW1200?Need to know!
brickie
What's up guys, yeah I know they no longer make this sub, but which one is better plain and simple???Room is 22ft x 14 ft, with 8 ft ceilings. I need to know which is better going to "pressurize" this room? Opinions needed fast!!
brickie
brickie
Post edited by brickie on
That size room, probally a PB2 +, PB2 ISD at the least...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I agree with sid - went from the PSW1200 to the PB2+ and thier is no compatition. The SVS is deeper, cleaner and much more pressure/spl.........Originally posted by Vr3MxStyler2k3
That size room, probally a PB2 +, PB2 ISD at the least... -
Thanks, will go check out the ones you guys mentioned!
brickie -
Is that popcorn brickie?My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
What's up man..Yes it's me!
brickie -
i am considering trying a diy cylinder subwoofer. any imput on how hard it is or how much it would cost?
thanks for the help -
Thinking about trying one myself..It looks like it would be easy to build, just wonder about the performance..
brickie -
If you can great good deals and make a really inexpensive DIY sub and know what your doing - i say go for it. Many companys send the box and all - just a matter of assembly.
The problem is i have read about some of these DIY's (especially cylinders) and I believe pride and a waste of time and money get into the way of how the unit actually sounds, and then compared to what.
My PB2+ is a fairly expensive but considering that the drivers are $300 each, the amp and the box itself - I'm not sure I could have put one together with same performance and price not to mention service and warrenty......... -
Tecmo,
Check out the EZ sub Shiva kit from www.creativesound.ca It is passive so you need to add a plate amp, about 250W+ should do it. The performance should be great, do a search on the Shiva driver from www.adireaudio.comGraham
