SVS cylinder or a Polk PSW1200?Need to know!
brickie
brickie Posts: 20
What's up guys, yeah I know they no longer make this sub, but which one is better plain and simple???Room is 22ft x 14 ft, with 8 ft ceilings. I need to know which is better going to "pressurize" this room? Opinions needed fast!!
brickie
Post edited by brickie on
    VR3 Posts: 29,696
    edited August 2004
    That size room, probally a PB2 +, PB2 ISD at the least...
  • scottvamp
    scottvamp Posts: 3,277
    edited August 2004
    I agree with sid - went from the PSW1200 to the PB2+ and thier is no compatition. The SVS is deeper, cleaner and much more pressure/spl.........
  • brickie
    brickie Posts: 20
    edited August 2004
    Thanks, will go check out the ones you guys mentioned!
    brickie
  • dholmes
    dholmes Posts: 1,136
    edited August 2004
    Is that popcorn brickie?
    My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
  • brickie
    brickie Posts: 20
    edited August 2004
    What's up man..Yes it's me!
    brickie
  • tecmo04
    tecmo04 Posts: 421
    edited August 2004
    i am considering trying a diy cylinder subwoofer. any imput on how hard it is or how much it would cost?
    thanks for the help
  • brickie
    brickie Posts: 20
    edited August 2004
    Thinking about trying one myself..It looks like it would be easy to build, just wonder about the performance..
    brickie
  • scottvamp
    edited August 2004
    If you can great good deals and make a really inexpensive DIY sub and know what your doing - i say go for it. Many companys send the box and all - just a matter of assembly.
    The problem is i have read about some of these DIY's (especially cylinders) and I believe pride and a waste of time and money get into the way of how the unit actually sounds, and then compared to what.
    My PB2+ is a fairly expensive but considering that the drivers are $300 each, the amp and the box itself - I'm not sure I could have put one together with same performance and price not to mention service and warrenty.........
  • gatemplin
    gatemplin Posts: 1,595
    edited August 2004
    Tecmo,
    Check out the EZ sub Shiva kit from www.creativesound.ca It is passive so you need to add a plate amp, about 250W+ should do it. The performance should be great, do a search on the Shiva driver from www.adireaudio.com
    Graham
