Sonos or Fire Tv?
124»
  • vcwatkins
    vcwatkins Posts: 1,993
    Doubt it helps, but I turned off my Airplay DLNA to make sure its presence wasn't giving me a false positive. Spotify-to-Spotify is still working. Device shows up as "Craig's Fire TV". When I was connecting using DLNA (to run Tidal), the device showed up as "FireTV@48".
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    edited April 2015
    I would expect that once you start using the pro app that Skip suggested, everything will meet your expectations. I have DLNA capabilities on my AVR that is stupid easy to use, but the Fire TV DLNA sounds better for some reason than streaming directly to Yammy. Since I started using the pro app I never use the net functions on my AVR. It is easy to use and sounds great. The Fire TV has some fantastic hardware (not stick) that will continue to improve for quite some time. I would like to see the Spotify app get fixed sooner rather than later, though. At this point I have resorted to using the PS3 to stream spotify to the HT.
  • mrbiron
    mrbiron Posts: 5,712
    The is no update, $hit is still broke and doesn't work. T-minus 2 days until return process starts.
    I'm at the point where I will start spotify premium with my PC, and run it with my phone. Guess I can survive with that for now. Wish the Fire had a client instead of a bridge.....
  • vcwatkins
    App still working here. How much have you guys had to drink? hehe
  • mrbiron
    I've had 4 rum and cokes....thats my pregame! :p
    VC, im going for simplicity and these round about ways aren't what im looking for. My wife use this when cooking and if i add extra steps that even confuse me, it becomes moot. I need the, turn on the amp, turn on the program, make music. That's all.
    I wish mine worked on my end like butter but the reality is, it does not. I'm not saying the Fire is a bad product. I'm just saying it doesn't work for me. Like i've stated, i have 2 days to un-F this situation before i throw in the towel and go back to tried and true.
    I still thank you all for the help. Others have/will read this thread and decide for themselves which way to go.
    REFILL!!!
  • vcwatkins
    <hiccup> Sonos <hiccup>
  • vcwatkins
    vcwatkins wrote: »
    @mrbiron, not sure if it's been brought up here before, but I believe a Premium Spotify account is required to connect.
    Edit: FWIW, I am still able to connect to FireTV Spotify from iphone 6 and PC Spotify standalone app. I don't think it's possible to connect from Mac or PC browser player.
    Yep, premium only. I think that's also needed for 320 IIRC.
  • mrbiron
    Then i'm screwed either way. I should cancel my Premium and go elsewhere.
    I could run Pandora and cut my losses but I already have an AppleTv that has Pandora which i know works. Or just leave my PC and a 10 USB cable in the mix and deal with it.
  • mrbiron
    edited April 2015
    DSkip wrote: »
    Your Fire might not be recognized without the app I told you to download in this case - I'm not sure. If you're not seeing it, download the app and go from there.
    Yeah i downloaded it hours ago. No dice.
    You owe me $4 ;)
  • vcwatkins
    The Airplay DLNA works for me on pretty much anything; but, on Tidal is sometimes sluggish.
  • mrbiron
    The problem with Airplay is im an android/pc user. You have to download 3rd party software to make it work. I tried the Airfoil program. My wife and I could noticeably hear a static in the sound. Scrapped it immediately.
  • vcwatkins
    You could try the $3 SBPlayer app that makes the Fire a Squeezebox Touch in all ways except Tidal streaming directly. You'd have to download the Squeezebox controller LMS and could control music from the PC where the LMS resides or your phone using Squeezebox or Peng app. This would include streaming Spotify, Pandora, Linn, pretty much all but Tidal. Personally, I'd probably cut bait.
  • jeremymarcinko
    Yes you do need the premium sub. but that does not change the fact that the app is currently broken. I confirmed that with Amazon customer service yesterday. My wife and I both have separate spotify premium subs, neither will connect completely with any of our fire tvs. It may not have issues with all devices but her gs5 and my HTC m8 both running lollipop will no longer connect.
  • vcwatkins
    Confirmed does not work here with my son's s5. However, it does work with my PC standalone Spotify app, which is what I thought OP wanted to do.
  • vcwatkins
    mrbiron wrote: »
    From the Airplay DLNA page: "This is a receiver installed on Android devices such as Boxes or TVs to receive media sent from your Apple devices, PC, and Android devices via AirPlay or DLNA protocol."
    Not sure why it wouldn't be working for you or why 3rd party software would be req'd. Regardless, Airfoil doesn't sound to me like it is applicable here. Did you try sending a song from Android's media player after starting Airplay? I'm not familiar with Android phones, but I would expect to see the Airplay button on Play or whatever it's called.
  • mrbiron
    vcwatkins wrote: »
    PC doesn't work either but yes, that is exactly what I want to do.
  • mrbiron
    Alright, with reading about 20 threads/articles, for some ungody reason, spotify will not release the "connect" feature for the desktop app. There is no reasonable explanation so like previously stated, i will hook my computer back up via USB cable and run as normal.
    Can't say we didn't try.
  • vcwatkins
    Working here on standalone PC app. I know you've gotta be very frustrated. This is the kind of time-eating stuff that makes me appreciate the frustration-free design of Sonos. Sorry I couldn't help.
  • pearsall001
    pearsall001 Posts: 5,226
    Way too overcomplicated...shouda got the Sonos...just saying. A world of music at your fingertips that even a toddler could hook up & use the system...just saying.
  • vcwatkins
    DSkip wrote: »
    There is nothing complicated about this process. I don't understand where you guys are getting this crap from? The issue is its simply not connecting, which they are working to correct. Since this is a big plus for premium users, you can expect it to get done. Spotify won't risk losing that $.
    However, since he doesn't want to do premium, its a moot point. Get off the damn Sonos high horse because he'd had the exact same issue with that system he is having now since he isn't a premium user.
    mrbiron wrote: »
    I took this to mean he has Premium. I am not on a "damn Sonos high horse". I was trying to help him all last night and this morning.
    DSkip wrote: »
    The Sonos has its place and I appreciate what it does, but it is not a superior product in this instance. It's simply another option that still wouldn't fit his needs.
    Hence, my Sonos rec.
    DSkip wrote: »
    Anyone considering using a Fire for streaming from other devices definitely needs to get that DLNA app that I recommended. It is a big key for the Fire to do what it does for this situation. It's a $3 add-on. If you go WD TV Live, it already has this function built in. I'm not sure if the WD TV needs the HDMI handshake, and if it doesn't, it might actually be the better device for streaming pure audio.
    The Spotify Connect is working and doesn't require DLNA.
  • vcwatkins
    Looks like my posts are more upsetting than helpful. I'll bow out at this point. Sorry I wasn't able to help. I wish you the best of luck, @mrbiron.
    Virtual handshake to you, @DSkip.
    Craig
  • voltz
    voltz Posts: 5,384
    I had a Sonos (two ones in stero) for awhile buy my Sister stole it... so I don't know anything about it anymore as you would have to ask her.
  • jeremymarcinko
    I also have used the desktop app numerous times to stream spotify to my fire tv's. I do hope they get this app fixed soon though. I am currently using the ps3 to stream spotify, which is another option if you have one laying around.
  • jeremymarcinko
    edited April 2015
    Mine is working. I deleted the app data and cache, playing from pc now.
  • jeremymarcinko
    Have you tried using the smartphone spotify app? I know that isn't what you want to do but it may get it to work until the app gets fixed. I grabbed my old GS3 and it connected right away. My pc app didn't recognize the fire tv until my old samsung connected, the the pc app and HTC worked again. Just saying this might be a work around until the app is repaired.
  • mrbiron
    I have spotify premium. There, now that takes all the guess work out of reading cryptic posts.
    What you guys are showing is exactly what i want to do but for some reason, it will not work. I have tried, and tried. I can't even get the Fire TV to show up in the list. My phones will not connect either which i find suspect. My return label is printed, but i won't be able to get to a UPS until saturday which means, 5 days now to figure this damn box out.
    The phones go into an endless loop of "Hmm, there is a problem".
  • mrbiron
    Wont even show up in my list....
  • mrbiron
    **** F$%^ER!!!
    Why does it magically work now!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • voltz
    voltz Posts: 5,384
    cause I fix it for ya :) your welcome! but you still own me $5 & a bottle of Wine!
