Sonos or Fire Tv?
13
  • mrbiron
    mrbiron Posts: 5,712
    Jeremy...Thanks, now that is helpful!
    So how do you connect the PC to the Fire wirelessly? Meaning, is there software to be installed on the PC that talks to the fire through the router? Once the communication is made, the fire takes control of all audio out?
    Now we are making headway!!
    I understand how the Sonos works with its software but the Fire is vague or maybe im looking in the wrong spot.
  • mrbiron
    Perfect! So now you just costed me more money with JRiver :D
    We're picking up a head of steam now.....
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    edited April 2015
    Plex software can also be used on the fire tv and installed on your pc for free. Although it does not give info on any file conversion that may be taking place.However, It does work very well and sounds quite good. Very easy to use as well.
  • cascius
    cascius Posts: 179
    edited April 2015
    In plex you click on settings in the Web browser on the server pc), then one of the tabs (at the top right) shows all the streaming in process. You can go there to check for file format etc...
    Main System:
    Front: SDA 2ATLs
    Center: CS2
    Surround: M40s
    Sub: PSW505
    Receiver: Pioneer VSX-1121k
    Amp: Carver AV 705x
    TV: Samsung LN52A650
    Media Player: Chromecast/Boxee Box
    BD Player: Sony BDP-S470
    Consoles: Xbox360, Wii U
  • vcwatkins
    vcwatkins Posts: 1,993
    TV on
    Connect FireTV to TV via HDMI
    Batteries in remote
    Plug AC to FireTV
    Fire on (either automatically comes on or hit Home button, can't remember)
    Connect to internet wifi or ethernet, choose network, enter PW
    Sign into Amazon
    Download Spotify app to Fire, open Spotify app
    Download Spotify Windows app to PC
    Open Spotify app on PC
    Play music on PC Spotify
    Click on Connect button (circled speaker icon) bottom right PC app
    Choose FireTV
    Control Spotify from PC
  • jeremymarcinko
    FYI the spotify app on the Fire TV is currently broken and Amazon is working on an update to resolve the issue. Just in case you go that route, its been broke for a couple of days. If I were a bettin man I would bet that Amazon is getting a similar Spotify app as the one that was just released on the PS3 last week. It is a much nicer app and I hope that is what is happening.
  • vcwatkins
    Weird... mine has been working all morning. At least on that end, hehe. Maybe that was the cause for it not showing up as a 'connect to' device from PC app?
  • jeremymarcinko
    Not sure. I have three fire tv devices and connect doesn't work on any at this point. Normally there is no problem. I contacted Amazon support and was informed that the issue is known, being resolved, and an update will be performed shortly.
  • Thorton
    Thorton Posts: 1,324
    vcwatkins wrote: »
    TV on
    Batteries in remote
    Plug AC to FireTV
    Sign into Amazon
    Choose FireTV
    So then, how are you connecting to your AVR or preamp? HDMI ARC from TV or the optical output on the Fire?
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
  • jeremymarcinko
    You can plug the fire tv into the hdmi input of the avr or the tv. The fire tv also has an optical out if you need it. The fire tv "stick" does not have an optical out, however.
  • vcwatkins
    Thanks, kind of an important detail that I left out, hehe. I run the HDMI to the Oppo and optical to the W4S dac on the music rig.
  • mrbiron
    Well, i was going to do the whole SURPRISE!!...Look what i bought thread but no need. My Fire shows up tomorrow. Then I get to come back and harass you all again.
    I won't thank any of you yet...... :D
  • mrbiron
    There is but im too lazy to drive the 9 miles down the road. Amazon can deliver to my doorstep tomorrow. You see, i sit in my car for 3 hours a day and going out of my way is a no no. Less steering wheel time makes me a happier person.
  • jeremymarcinko
    Did you get the fire tv or the fire tv stick?
  • mrbiron
    DSkip wrote: »
    100 phone calls a day. 3 hours a day in the car. Your avatar makes sense now.
    I'm a general contractor in charge of 200 grown babies that need constant care. :D
    You and I are not so different. You students, me a$$holes....
    I got the Fire TV.
  • jeremymarcinko
    Good decision. You'll like it.
  • mrbiron
    I got there with the help of you's guys...
    Tony, if it doesn't work, i'll run to the Sonos :p
    Don't think it was all in vein, we had a long road to travel to get to this point.
  • voltz
    voltz Posts: 5,384
    lol you as bad as me I swear, my yearly credit card report show I spend cost to $5k a year with Amazon.
  • mrbiron
    Well, let me tell you how truly disappointed i am right now. My phone will not connect using the Spoitfy App. Just goes into an endless loop and says Hmmm there is a problem.
    My computer will not even recognize the Fire on the same network. Im going to keep digging into that part as to why this is happening. Some firewall/network setting...???
    I can hot swap between my phone and computer just fine. Why i would want to do that is beyond me but i can. :|
    Like i said, i won't discount it just yet as i've only had it for an hour but i get frustrated easily.
  • mrbiron
    Frustration continues.
    Doesn't recognize wife's iphone5
    Doesn't recognize my Android
    Doesn't recognize windows pc
    Doesn't recognize wife's imac
    All can connect between each other no problem with my Premium account.
    http://www.amazon.com/Spotify-Connect/product-reviews/B00N1XIY5Q/ref=cm_cr_dp_see_all_summary?ie=UTF8&showViewpoints=1&sortBy=byRankDescending
    Reviews all say it sucks.......
    Issues with US spotify and amazon and nobody will rectify it?
    Help. :s:s
  • mrbiron
    DSkip wrote: »
    That is an issue I did not run into. Did you download the DLNA app? When I get home, I'll see what its called. It's like $2.99 and has Airplay/uPNP/DLNA support.
    Hurry up...my beer is getting warm.... :D
  • jeremymarcinko
    As I mentioned, the spotify app is currently broken, and Amazon is working with spotify for an update. Its been down about three days now.
  • mrbiron
    According to the reviews, its been down for 1/2 a year :D
    Hope is not lost as i've walked away from it before i have a broken remote on my hands...I will return when my beer kicks in!
  • jeremymarcinko
    No. I have three fire tvs and have never had issues with spotify until now.
  • mrbiron
    You're using all of Spotify's bandwidth!!!
    I'll download the program and check back in....
  • vcwatkins
    I am able to connect with iphone.
    You opened Fire app, chose phone as device, opened phone app, clicked speaker icon bottom right of now playing screen?
  • mrbiron
    You betcha...Im going to try the DLNA app Skippy uses tomorrow.
  • pearsall001
    pearsall001 Posts: 5,225
    Shouda got the Sonos...just saying.
    tonyb Posts: 33,065
    LMAO !!
    Not at the OP per say, it's just that these are the aggravations I'm talking about that will emphasize your inner Norman Bates tendencies when you just want stuff to work.
    Nothing aggravates me more than digital that's a pain to operate or setup. I don't want to be a babysitter to it either.
    Spotify too was always spotty when I used it. Rhapsody has always been rock solid for me.....and Tidal is going down the tubes quick judging by some stories I've read.
    That said, I do hope the Fire stick eventually works out for you. It is a cheap alternative, one of them anyway. Good luck to you, hopefully Dskip will get you straightened out with it.
  • vcwatkins
    edited April 2015
    @mrbiron, not sure if it's been brought up here before, but I believe a Premium Spotify account is required to connect.
    Edit: FWIW, I am still able to connect to FireTV Spotify from iphone 6 and PC Spotify standalone app. I don't think it's possible to connect from Mac or PC browser player.
