Another round of SDA Circuit Boards - Maybe
Trey has 6 sets left and I'm trying to decide if I'm going to have another run made.
Is there enough interest to warrant a run of 25 sets (anything less is just not worth it). Or should I just stop before I get stuck with a bunch of boards I have no use for and be out a chunk of change.
  • gimpod
    gimpod Posts: 1,793
    edited April 2015
    That's wired I just got a message saying my response to your question would be posted as soon as it was approved.
    Just goto my or Trey's vr3mods.com site.
    Post edited by gimpod on
  • vcwatkins
    vcwatkins Posts: 1,993
    edited April 2015
    gimpod wrote: »
    That's wired I just got a message saying my response to your question would posted as soon as it was approved.
    Just goto my or Trey's v3rmods.com site.
    vr3mods.com
  • gimpod
    gimpod Posts: 1,793
    edited April 2015
    SORRY! :blush: I'm on drugs today, come to think of it I'm on drug everyday. :tongue:
    Thanks, Just fixed it. Thank god for the one hour edit.
  • gimpod
    gimpod Posts: 1,793
    Same as all the others $100.00 a set. It's the same board for all the forth and fifth gen SDA's 2B/CRS+, IC, SRS 2 (Pin/Blade), 3.1TLL, 1.2 and the 1.2TL
    Check out my web site or you can order them here from, Trey Custom Not Polk SDA Circuit Boards Pair
  • gimpod
    gimpod Posts: 1,793
    edited April 2015
    Duplicate post. Man you just gotta love this forum software. NOT!
    F1nut Posts: 51,749
    Tony, it's like Larry's rings. As soon as they are no longer available, everyone wants them.
  • Schurkey
    Schurkey Posts: 2,122
    If you build them...they will come.
    Go for it. Sooner or later you'll sell every one of them. I felt the same way about the polyurethane front suspension bushings for Toronado/ElDorado, but I commissioned a second run; and I'm almost out of those.
    VR3 Posts: 29,425
    Hey,
    Ya know me, I am willing to help where I can... :) The Gimpod boards are great and have been an excellent modification for me...
  • woofiepaws
    woofiepaws Posts: 222
    I'd take a pair for my CRS+s
    VR3 Posts: 29,425
    I have some available, I can include them in your harness shipment.
  • woofiepaws
    Make it so, Trey.
    nooshinjohn Posts: 25,915
    Schurkey wrote: »
    I am looking for a 66 Toro as we speak. needs to be a decent car that can be enjoyed a bit, and I am stunned by how much coin they are going for these days.
    gudnoyez Posts: 8,161
    Are the boards necessary on the TL mod on the 2B's and CRS+? I need to do these mods and keep putting it off. I'm still undecided which ones to mod first. I'm leaning towards the CRS+s first.
  • vmaxer
    vmaxer Posts: 5,120
    I may take another set.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    F1nut Posts: 51,749
    They aren't necessary for any SDA, but they make it MUCH easier and Tony's boards are of MUCH higher quality.
    Tony I would be interested in a set.
  • PolkieMan
    PolkieMan Posts: 2,446
    They made the entire upgrade painless and easy. They provide the extra working room for the much larger caps.
  • headrott
    headrott Posts: 5,496
    Yeah, after doing 3 sets of SDA's with Tony's boards; I must say it's doing SDA crossovers for "dummies". :smiley:
    If you have SDA's or plan on buying some in the future, you need a set or 3 of these boards.
    F1nut Posts: 51,749
    WAAAAAAAAAAAAAAAAAAAAAA
  • Nightfall
    Nightfall Posts: 10,084
    afterburnt wrote: »
    Village Idiot of Club Polk
  • gimpod
    gimpod Posts: 1,793
    Hey all I just a quote from a company that can do 2 colors (black on top and green on bottom) Which if they can meet my standards I will do. But first I'm seeing if they'll run off a single set so I can check the quality and if they do then were in business.
    VR3 Posts: 29,425
    That's awesome
  • westmassguy
    westmassguy Posts: 6,850
    gimpod wrote: »
    Sounds like a good plan
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • What do these cost? I may also be interested
    2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
  • Seems very reasonable. Do folks mount the larger erse sub bass complimentary inductors on these boards also or remote mount those?
    SCompRacer Posts: 9,112
    Just a suggestion, maybe use google docs like they do for the group buys at diy audio. Folks enter their name, what they want. Once you get to or past the number of boards that makes it worthwhile, you close the GB and make your order.
    https://www.google.com/docs/about/
    An example.
    https://docs.google.com/spreadsheets/d/1L6k7HAUnjGq9E8KBfIGz6SJ-vrsQGGyQrV-R8c4qBG0/edit?usp=sharing
  • vcwatkins
    I'd be in for a set. Thanks, @Gimpod.
    Craig
    edited April 2015
    Oops wrong thread my apologies
  • voltz
    voltz Posts: 5,384
    unless it was possible to change the words to say " A Briefcase full of Circuit Boards" B)
  • audio_alan
    audio_alan Posts: 770
    Still no love for the original SDA-SRS's (non 1.2/1.2tl)?
