Squeezebox Touch or Sonos
I have a chance to pick up a Touch for a decent price for my bedroom system. What is the support going to be for the Touch in the coming years?
Or should I just get another Sonos Connect for my bedroom system?
Thanks for your thoughts.
Scott
I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • gimpod
    gimpod Posts: 1,793
    Something to think about Logitech no longer makes the Touch or any Squeezebox since 2012. -- Just saying.
  • Emlyn
    Emlyn Posts: 4,868
    Logitech still puts out the occasional minor update to its Media Server software every few months. They are not making the hardware now of course. Mine still work just fine, streaming from a computer with Windows 7 as the operating system.
    What it will lack in the future is keeping up with the latest music streaming apps, but I never cared about that aspect of it anyway. Internet radio works fine still. If someone is mainly just interested in streaming their own stored music the system should be good indefinitely, and it does a great job at that function.
    I'd just get another Sonos....why have 2 different operating systems. Especially since this will be for a bedroom.
  • Emlyn
    Emlyn Posts: 4,868
    tonyb wrote: »
    I agree with that approach. No sense in starting another system if one linked system is in place already.
  • polk500
    polk500 Posts: 1,171
    Also in as far as the squeeze box goes Ipeng HD support the SB and is current with updates. Also cheaper then sonus. I tried the sonus but didn't see the point in other operation system. Hmmm sound familiar doesn't.
    Cheers
    Roger
  • nspindel
    nspindel Posts: 5,343
    I'll never part with my squeezebox touch. For the purpose of high resolution playback from a hard drive it is outstanding. The downside is that you need a server but as long as you run a machine for it squeezebox touch is really really good.
  • polk500
    The Squeeze Box also works well with my Logitech Remote. And I would imagine the sonos would as well.
    Cheers
    Roger
  • Well guys, I have not bought the Touch. I use a Touch in my main system now and I am very pleased with the way it sounds. I was given a Sonos Connect and use that for my whole house system and it works and sounds great for that application. I am currently using a Apple Airport Express as a source for my bedroom system that I was thinking about buying the Touch for. So I have 3 formats. I think my best bet is to get another Sonos Connect because it would work best with my intent of the system(s). But the Sonos Connect is the most expensive. I am in no rush.
    Thanks of your thought,
    Scott
    Scott, the connect comes up on your local craigslist fairly often for under 3 bones, seen some for 200 on mine.
  • cascius
    cascius Posts: 179
    I sold my connect (mint condition) for $280 a couple months ago. These do hold a value nicely.
    Good luck!
    Main System:
    Front: SDA 2ATLs
    Center: CS2
    Surround: M40s
    Sub: PSW505
    Receiver: Pioneer VSX-1121k
    Amp: Carver AV 705x
    TV: Samsung LN52A650
    Media Player: Chromecast/Boxee Box
    BD Player: Sony BDP-S470
    Consoles: Xbox360, Wii U
  • RamZet
    RamZet Posts: 792
    polk500 wrote: »
    Cheers
    Roger
    Sonos can only be controlled by the app. They dont have ir, ip, or rs-232 support.
    The ip support that is our there is lame.
    But the app is awesome.
    B&W CM9Classé Sigma
