Is it really FLAC?
I ripped several CDs to my hard drive in FLAC format using Media Monkey. I have no problem playing them via DLNA on my AVR. When I display the file info on the AVR it says 160kbps. Does this make sense? I thought the bit rate should match what I see on MM which is considerably higher and varies by song.
HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
BR - Yamaha CR800/Polk monitor 5
  • gcegce Posts: 2,186
    I've ripped 100's of CD's with dbpower to FLAC. Running them out of my NAS to the Marantz it always displays FLAC 44.1KHz.
    Anaheim Hills CA,
  • drselectdrselect Posts: 663
    Nope it doesn't make sense. But I also use dbpower to rip to FLAC and MM for file playback.
  • NightfallNightfall Posts: 9,311
    edited February 2015
    I wonder if it is being converted on the fly?
    Try putting a FLAC on a USB stick and playing it directly from the stick. Does it still say 160kbps?
    afterburnt wrote: »
    Village Idiot of Club Polk
  • Look for the "decoder" info not sampling rate.
  • recoveryonerecoveryone Posts: 809
    I guess the first question should be, does the AVR support FLAC playback in native form? or does it down convert. Just as with some HighRES CDs, a downmix will play if your transport does not support the native format. But 160 Kbps is very low even lower than 320Kbps for Mp3.
    Family Room HT 7.2/i]:
    Vizio P55-E1UHD Pioneer Elite SC-LX502 Pioneer Elite BDP 85FD Pioneer Elite N-50 Panamax M5300-EX
    Living room 2ch:
    Integra ADM 2.1 Teac EQ MKII Squeezebox Touch Fluance SX Speakers Panamax M5100-EX
    Upstairs media room:
    Vizio D1 32" Pioneer Elite VSX 32 Sony PS4 Squeezebox Touch Polkaudio Rti 6's fronts Polk CSR Center Polkaudio PSW 10 sub Panamax M5300-EX
    Master bedroom:
    Vizio VF550M Pioneer Elite VSX 33 Pioneer Elite BDP 80FD Squeezebox Touch Polk audio Monitor 40 II fronts, Rears Dayton B652 Polk Audio CS10 center Polkaudio PSW 10 sub Panamax 5100
  • When I access the server the display on the AVR says MP3160kbps 16bit/44.1kHz. When I tried the USB port the display on the AVR said FLAC 842kbps 16bit/44.1kHz. I also found a footnote in the manual stating "in the case of server playback, the below-mentioned file formats may not be played depending on the server type".
    So it looks like something is converting it on the fly before DLNA takes a hold of it.
    afterburnt wrote: »
  • I had the same problem with jriver until I found the setting in jriver to play the native software.
Howdy, Stranger!
