Is it really FLAC?
I ripped several CDs to my hard drive in FLAC format using Media Monkey. I have no problem playing them via DLNA on my AVR. When I display the file info on the AVR it says 160kbps. Does this make sense? I thought the bit rate should match what I see on MM which is considerably higher and varies by song.
HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
BR - Yamaha CR800/Polk monitor 5
  • gce
    gce Posts: 2,158
    I've ripped 100's of CD's with dbpower to FLAC. Running them out of my NAS to the Marantz it always displays FLAC 44.1KHz.
    Anaheim Hills CA,
  • drselect
    drselect Posts: 664
    Nope it doesn't make sense. But I also use dbpower to rip to FLAC and MM for file playback.
  • Nightfall
    Nightfall Posts: 10,071
    edited February 2015
    I wonder if it is being converted on the fly?
    Try putting a FLAC on a USB stick and playing it directly from the stick. Does it still say 160kbps?
    afterburnt wrote: »
    Village Idiot of Club Polk
  • jeremymarcinko
    Look for the "decoder" info not sampling rate.
  • recoveryone
    recoveryone Posts: 885
    I guess the first question should be, does the AVR support FLAC playback in native form? or does it down convert. Just as with some HighRES CDs, a downmix will play if your transport does not support the native format. But 160 Kbps is very low even lower than 320Kbps for Mp3.
    Family Room HT 7.2/i]:Vizio Oled55h1 Pioneer Elite SC-LX502 Pioneer Elite BDP 85FD Eversolo DMP A6 Panamax M5300-EXSpeakers Fronts Fluance XF8L Center Polk Audio S35 Side Surrounds Optimus LS30's Rear Surrounds Optimus LS30's Subs SVS PB4000 x2 Living room 2ch: Crown Xli 1500 amp Teac EQ MKII FX Audio X6 Mk II DAC Squeezebox Touch Fluance Signature Tower Speakers Panamax M5100-EXOffice media room:Vizio M50Q6 50" Pioneer Elite VSX LX103 Squeezebox Touch Polkaudio R50 Towers Polkaudio CS 10 Panamax M4300 Monoprice 12" subMaster bedroom:Vizio M55Q7 Pioneer Elite VSX LX302 Pioneer Elite BDP 85FD Squeezebox Touch Polk audio RTi 6 fronts, Rears Dayton B652 Polk Audio CS10 center Monoprice 12" sub Panamax M5300-EX
  • Easy Runnin
    When I access the server the display on the AVR says MP3160kbps 16bit/44.1kHz. When I tried the USB port the display on the AVR said FLAC 842kbps 16bit/44.1kHz. I also found a footnote in the manual stating "in the case of server playback, the below-mentioned file formats may not be played depending on the server type".
  • Nightfall
    So it looks like something is converting it on the fly before DLNA takes a hold of it.
    afterburnt wrote: »
  • jeremymarcinko
    I had the same problem with jriver until I found the setting in jriver to play the native software.
